Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The good old short travel problem-however.....
I went through the steps to install a new gear and screw. When I put the lift back together, it did the short travel thing. I read the solutions on this site and followed the instructions. I put the collar as far forward as it will go and reinstalled the cap and tested. Same thing. My opener is pre-1988 and the kit I received was a little different than the original. The kit had the collar being described here, but the original was held on with a brass busing. As I read the instructions, yup I read them, first time for everything, I installed the collar just as instructed and pictured. It looked just like the schematic. It is as far forward as it will go, I even stopped the thing in mid cycle to account for shaft travel caused by the screw pulling the shaft back as it turned. Now what? My pride is on the line now, I gotta get this thing to work.
    Guru:
  • 1,342 Answers
C/E light on for 1 code P0741, changed TCC solenoid, trans fluid, filter why would the transmission stop going into gear after previously shifting beautifully with no slipping or any issues at all.
Just because you installed a new part, do not assume it can't be bad. This happens alot with aftermarket parts. When you change just a minor part and a problem develops, good idea to double check both your work and the new parts.
Apr 14, 2015 | 2002 Cadillac Seville SLS
How disconnect speedometer peugeot 406 hd
put on lift and follow speedometer wire down back behind engine and just unscrew. The should stop it from working. You probably want to replace the speedometer by removing trim then unscrewing bolts/screws until you can remove the cluster panel. remember to remove all the stuff attached to back of it. then unbolt speedometer and install new one, but remember in some states that has to be done by a state certified person that would set it to the old amount of miles traveled. Someone had done it without setting it for current miles traveled and sold it to our Police Department and it was determined that the cars had 300,000 miles on it and not 5,000 so they were set to jail.
Apr 29, 2014 | 1999 Peugeot 406
1/2 horse garage door opener doesn,t open all the way. I need about a foot more lift. The tried a trolley stops before the stop limit..Therre is no interference. I Tried adjusting the up limit to no...
You said you adjusted the up limit already. Is it adjusted as far as possible? Usually the screw will become harder to turn. You mention a new door and spring but is the opener the same? My guess is you have a new opener as well and it is out of sync with the trolley. Try turning the up limit back and see if the trolley will stop shorter. If it does, loosen the chain or belt so that you can remove if from the opener's drive gear. Bring the trolley to your stop limit and put the chain/belt back on the gear. Adjust the chain/gear tension and try door operation again. If it was a sync problem, the door should close closer to your limit. Adjust up and down travel as necessary to fine tune it. This worked for me so good luck.
Sep 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
BELT INSTALLATION
the way you install the belt is different depending on the model - the most common kind is whirlpool and kenmore. to install the belt on them you must first pull out the dryer filter on top and then unscrew using a phillip head screwdriver, the two screws on top underneath it. then with a flat head screw driver pop the front up off the dryer. Next you must unscrew the two front inside corner screws using a 1/4 or 5/16 and unsnap the right side lid switch wires. lift up and out to take the front of the dryer loose. now you can put the new belt around the tub and loop it around the bottom belt guide to the moter. Follow the steps in reverse to put everything back together.
Jul 16, 2011 | Dryers
I have two white wire bond together, then two red wires and two black wires how do I wire this switch?
You posted under 3-way switch.
Example of 3-way switch is a hallway with switch at each end of hallway.
If you have a different switch, then instructions below do not apply, so add a comment.
1) Your old switch has 3 screws: 1 dark screw and 2 brass screws.
New switch has same color screws.
If you can remember where wires went on old switch, then re-connect on new switch using color-coded screws.
This is why I learned to make notes or take a photo before disconnecting electrical device.
2) If you are uncertain where wires went on old switch, then we can test.
The testing takes more words than it does work, and it will resolve problem.
You are replacing one 3-way switch, but other 3-way switch is still in the wall and is wired correctly.
We will call the other switch: switch2
Move switch2 to down position.
Separate wires at new switch for testing.
Use ordinary two wire tester.
Tape tester leads to wood to keep hands away from power
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Mark this wire.
Now move switch2 to up position and repeat test.
Tester lights up on Hot wire so mark this wire.
>If same wire is Hot in each test, then this wire connects to dark screw. If this wire was also connected with another wire on old switch, then connect that other wire to brass screw also.
>If two different wires tested Hot, then these are the travelers, and each traveler connects to a brass screw. One traveler on one brass screw and other traveler on other brass screw, in any order.
Leave switch2 in up position. One wire is Hot and has power.
Test this wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire(s). This wire(s) is not used in the 3-way circuit, so put a wire nut over Neutral.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 11, 2011 | Leviton 5603-02W Decora Rocker 3-Way AC...
Interior door handle right side
first you need to order a new handle and trim ring, 2 separate pieces. beige or grey are your only choices. www.tnaautoparts.com cheapest and only one i found that caries beige. i did both front doors for 25 dollars total including shipping. Remove door panel, 2 screws under round plastic caps that pry out and off, 2 screws at bottom, 2 lg screws in middle handle, 1 plastic retainer in side that prys out, 1 screw under square cap in the center of the trim ring. remove black plastic triangle shaped piece near the mirror, prys off easy. grab door panel and pull out then lift up. leave wires attached and let panel hang loose. remove screw from old door handle. remove linkage from handle and from lock. connect linkages to new handle and lock (look carefully at the old one before you remove the linkages) , install the last screw you removed to hold lock in place while you check to if everything works. when i finished mine neither door would open from the inside. i had to take pliers and slightly bend the linkage at the elbo's to shorten the travel distance. check this before you put everything back together by just putting the door panel back in place down fist then in, window down, close door, reach in and open door, if it doesn't open bend linkage and try again. when you are sure everything is ok install all screws except the one that was under the square plastic cap in the trim ring. to install trim ring look for notch on back side toward front of ring, push ring in notch end fist, back end slightly out, when the front end is in and seated push the back end straight in. install screw and push cap in. this job is not as hard as it sounds and will make sense when have the panel off and can see.
Nov 07, 2010 | 1998 Toyota Camry
Mixer head loose
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
Install hard drive in hp a1310n
You need to do a number of things:
1) You need to carefully remove the door and the whole front face of the desktop (the front face opens like a door it swings open from left to right)
2) Once you have the front pannel open take a philips screwdriver and unscrew the memory card readers that is show in front of the deskop (there is one screw holding this card reader in place probably on the upper right hand corner.
3) Carefully remove the card reader by jiggiling it lightly till the unit comes off.
4) After you remove the card reader, you will immediatly see the hard drive directly behind the reader that you just removed.
5) Now look inside the desktop (because you removed the right hand side door: the big one that alows you to see inside the pc) and remove all cables from this hard drive before you read #6 below
6) Inside the desktop, Locate the hard drive, put your hand on the back of it and lift on the green plastic part along side the hard drive where you can see the harddrive screw which is on a metal track stopped by a green plastic stopper.
7) Lift the green plastic stopper and push the back of the hard drive to the front of the desktop.
8) Unscrew all screws from old hard drive and rescrew them on the new one in the exact same spots at the old hard drive.
9)Once you finish screwing on the screws, slide the new hard drive back from where the old one was
10) reconnect all data cables and power supply cable.
11) follow steps 7 thru 1 to put unit back together again. Go thru steps 7 thru one backwards
I hope this helps
Mar 18, 2010 | HP Pavilion a1310n PC Desktop
Window falls down both rear windows . i could fix it if i new how it worked or if i had a diagram to see how it goes together
The lifting gear has probably broken - its plastic !
take off door covers (screws in door pull, clips around edges,unclip plug to door switch and speaker) you will then have to remove inner lining (be carefull and you can refit it) you will then see the lifting gear. push the pin out of the lifter bracket to glass bracket to seperate.
buy new lifter if unrepairable - keep old window motor to fix to new lifter - as these are sold extra (I know it sucks - new lifter + old motor)
good luck
Apr 25, 2009 | 2000 Jaguar S-Type
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
95 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
