Question about Danby DCD5505W Electric Dryer
Blowing heat, not spinning!!!!! - Danby DCD5505W Electric Dryer
  • Danby Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
  • Danby Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Simpson minimax dryer not getting hot does spin timer works will run for about 2minutes then blows fuse
It is most likely a failed heating element, when it attempts to heat it causes a short, blowing the fuse
Jun 05, 2016 | Dryers
Dryer heats up and blows air but is not spinning. What's up?
The problem most likely is a stretched or broken belt. This will have to be replaced to restore proper operation.
Feb 28, 2015 | Dryers
Doesn't spin but it heats and blows air
probably the belt snapped that spins the drum
Feb 01, 2012 | Roper RES7646KQ Electric Dryer
Our window AC/heat unit fan only buzzes when turned on- no matter whether you turn on fan only or heat or cool mode.
so the fan does not spin and blow air? it could be a stick broken fan try free spinning it make sure its turned of. if fan spins freely its probably your start capacitor which is not to expensive.
Nov 10, 2010 | LG Heat cool Window Air Conditioner
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
My dryer works (spins, blows air) but it won't hea...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Dryers
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
Danby DCD5505W Electric Dryer Logo
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
