Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Door will not go up or down. Lights do not come on.
    Problem Solver:
  • 15 Answers
The power is not feeding to your opener. Something is either A) wrong with the outlet you are using to power your opener or B) the opener has malfunctioned. Test your outlet to make sure it has active current. If there is any programming issues with this opener, it should have flashing lights at least.
Posted on Nov 01, 2010
3/4 hp Craftsman garage door going back up when closing.what shiuld i do?
If it completely closes and then goes back up and the lights are NOT flashing adjust the down limits (its going down to far). If the lights flash repeatedly then something is tripping the safety sensors. Finally if its going almost all the way down and then comes back up adjust your down force.
Oct 30, 2016 | Building Materials
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
Inside lights will not turn off. Bypass?
Your door needs to be replaced I would kick ,pry, pull what ever it took to get door open.The switch that turns out the light is the door latch itself. Either take off the kick panel by your left foot and disconnect wire or cut hole in door and disconnect wire.If a battery goes dead it will never come up to full power again have it replaced under insurance
Nov 27, 2011 | 2004 Chrysler Pacifica
Gararge door lights blink door starts down and then returns to open I have replaced sensors at door opening checked wiring and adjusted down pressure
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are on and are not blinking or that one is not dimmer than the other. Check that the 2 solid white wires are connected to terminal #2 and the 2 wires with the black tracer are connected to terminal #3.
Aug 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
My door will not go down from remote.It starts,jerks and quit ,lights flash.It is the same from main wall remote also.I have to hold down the the master button for door to go completely down
It is safety "eyes" sensor issue with your system. Lights flashing on the main console indicate a potential problem. Model up, from yours WD962KD, I believe, has a "smart" wall mountable remote that displays a potential problem. In your case, I would check that both safety "eyes" sensors are working (both should have lights on, one amber and one green). Post if you need more help.
Aug 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Interior lights run battery down when car is turned off.
Are you saying the interior lights don't shut off after the door is closed, or that the interior lights, when they're on for a short time, run the battery down?
If the lights stay on when they should shut off, there could be a bad door switch that's not registering that the door is closed.
If the lights being on for a short time when the car isn't running is running the battery down, your battery may be getting close to the end of it's lifespan & need changed.
Aug 17, 2010 | 1999 Dodge Intrepid
1998 Grand Voyager: overhead lights on and off and door ajar light on ...
sounds like one of the door switches have come loose and causing it to earth out and activate the interior lights while driving which will also activate the chime.
May 17, 2010 | 1998 Plymouth Grand Voyager
It goes up about 10 in. and then down about 10
You most likely have a broken door spring or a stripped drive gear. If by LED lights you mean the door sensors, they only work when the door is closing.
Jan 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lights blink door only moves a little
check the eye sensors to see if they are lned up with each other, one shouled show green, maybe one was moved by mistake
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door blinks 10 times, both sensor lights are off
sounds like two problems. you've disengaged the door and you can't manually pull down? try taking arm off door. As far as eyes go, need more info. If both lights out, you have a break in wire or bad logic board. Need more info.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
120 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
Owen Barnes
OtherBrother
Level 1 Expert
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
