Question about Thermador Microwave Ovens
Did Thermador range model ESC30 require 240 volts?
    Champion:
  • 248 Answers
I searched this model,but all i could figure out is that it requires a 3-wire 40 amp cord .wich i believe is used for 240 volt applications.sorry couldnt be more help
Posted on Oct 12, 2010
Thermador 01
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Oct 25, 2013 | Thermador MBES Microwave Oven
Cm302b
see the following steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Thermador MBBS Microwave Oven
Hot plate just wont turn on...switches checked in meter box and no iscolating switch. baumatic ceramic cook top. BA 13.2 ( i think) house just been sold. Hotplate wked thurs. House sold Fri. new owner...
Hello, is this a two electrical filament hot plate? Also, is this range stove/oven? I'm a little confused here on what exactly what you are referring to hot plate or cook stove with electrical burners and oven. If it a really old hot plate with one burner look at the plug there could be a fuse in it. If it is electrical range then check the control board and see they a fuse on. If not, check the voltage with a volt meter. Be very careful here there two phase that is 240 Volts AC. The voltage will be split between the two l20 hot legs AC which is 120 degrees out of phase in respect to each other; in other words, don't both of them don't let them touch each other.
If it a kitchen stove I'm fairly sure that the control board is shot and with this not operating it will not open the current/voltage relays for the electrical burners. REMEMBER YOU ARE DEALING WITH 240 VOLT AC...BE CAREFUL.... GB....stewbison
Aug 26, 2011 | Baumatic Microwave Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
Whirlpool range problem - lights etc on, but no heat from stove/range.
check the circuit breaker or fuses connected to the range
thelights will operate at only 120 volts but its takes 240 volts to heat
since no burners or oven elements heat that seems the breaker is the problem
anothe very probable cause is where the cord connects to the range their is a burnt connecting which would require repalcing the pigtail(range cord) and terminal block
Jul 18, 2011 | Whirlpool Microwave Ovens
Need to know amps for installation, please. thank-you
Look for the sticker in the back you should have the Amps, the Volts, the Power, if you have the Voltage and the Power than you have to do a litle math... the Amperidge is obtained from deviding the Power from the Voltage ex:
Voltage is 120 volts, Power is 90 Watts than the Amps would be 0,75 Ampers (90W / 120V = 0,75A)
Cheers!
Mar 21, 2011 | Microwave Ovens
Thermador RES 30 range. I need wiring color and connection assistance to the display assy. I sent the display in for repair and now I am re-installing it. I thought I marked the connections down...
That is proprietary Thermador information, they are the only ones that can provide that. Was it Thermador that you sent the display into for repairs? If so they should definitely be able to give you the information you need. Do you need their phone number?
Please let me know and I can definitely help, thanks
Tim
Sep 10, 2010 | Thermador Microwave Ovens
Need to remove microwave over the range whirlpool model mh1141xmq0
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes if you need to send it in for service.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 05, 2009 | Whirlpool Microwave Ovens
Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Sep 16, 2009 | Thermador MBBS Microwave Oven
I need to install this range in a new kitchen and need to know the electical specs of the supply power
I don't see what range you're referencing. I see a title of microwave ovens. But, in any event, here's circuit requirement for each.
If it's a cooktop range: 220 volt 30 amp dedicated circuit
If it's a microwave: 110 volt 15 amp dedicated circuit
Charlie
Aug 22, 2009 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Thermador Microwave Ovens Experts
William Miller
William Miller
Chuck
Jerry Greenberg
Jerry Greenberg
Are you a Thermador Microwave Oven Expert? Answer questions, earn points and help others
