Question about Sony PlayStation 2 (PS2) Console
No screen or sound
I bought a new gta vice city disk for ps2 and i almost beat it. but after the game loads the memory card loads my file, says load successful and then the screen turns black and you cant hear it. the game works fine without the memory card in it, but not with it in. how do i fix it?
    Problem Solver:
  • 14 Answers
I have had this problem numerous times. It's a glitch in the game, best I can figure. It corrupts your saved game. You might be able to go back to an earlier save and play from there. But the best solution, if that doesn't work, is to take out the game disc, turn on the ps2, click on Browse (with your memory card plugged in) and delete the Vice City file(s) on there. Then put your disc back in and start over from the beginning. It sucks, I know. I've had to do it. And once I was almost to a 100% completion. Bleh. =( Sorry.
Posted on Jul 27, 2009
SOURCE:
When i open my GTA vice city it says that not enough video memory... What is it..???
Your version of the ps2 cannot handle the graphics for the game. Which likely means your ps2 has become defective and has trouble running the game. A new ps2 should fix the problem since the game only requires 32MB of system ram and 4MB of video ram as stated in this thread.
http://forums.anandtech.com/showthread.php?t=1541567
Hope this helps : )
Dec 30, 2010 | Rockstar Games Grand Theft Auto: Vice City...
How to install steed mod in gta vice city ? the pc game
Gta vice city to click vice city
to loading then loading to eror
Sep 15, 2010 | Rockstar Games Grand Theft Auto: Vice City...
GTA Vice City Error
I had this problem it's not from the ps2 it's from the disk. For some reason gta disks don't want to corporate with the slightest of scratches.
Mar 14, 2009 | Rockstar Games Grand Theft Auto: Vice City...
GTA Vice City Error
It may not be your game disk at all so I'd probably give the alcohol, toothpaste and whatever else you've been using a rest.
My first PS2 used to overheat a lot, so what I used to do was unplug the AC adapter (after shutting it off) from the system when I wasn't using it and that seemed to help.
Also, regular cleaning with a good laser cleaning kit helped extend its life but eventually it just burned out after about two years.
If you have a small electric fan that you can direct at your game system while you're playing, that will help the system temperature stay cool enough to play beyond the 20 minute mark.
GTA Vice City is pretty graphic intensive, and I'm guessing that since you have an older machine it may just be taxing your PS2's resources.
Probably not what you wanted to hear, but the good new is that it plays great on PS3.
Regards, ~ redqew ~
Mar 11, 2009 | Rockstar Games Grand Theft Auto: Vice City...
Gta vice city loading problem
I had the same problem- Wash the back of the disc with windex and a paper towel. It should work because it worked for me.
Jan 04, 2009 | Rockstar Games Grand Theft Auto: Vice City...
Vice City Ps2 game not working...
Sound like either a corrupted memory card saved game (your Vice City save), or more likely, your laser lens needs cleaning or replacing. First, try taking out the game, go into the Browse menu (with your memory card still plugged in) and find your Vice City save file in your memory card... delete it. Now put the game back in and let it start a new game. See if you can play it, save it, load it, drive all around, go through a "cut scene" (video story part at the beginning of each mission), etc. If you can do all that, it was most likely the corrupt saved game. It does happen on occasion with Vice City.
The lens issue is a little more detailed. You can relatively easily clean the laser, but you have to be SUPER careful with it. Don't touch it with your fingers/skin at all. You can find guides to cleaning the lens on the net. There's even a video or two of it on Youtube. If that doesn't work, your lens MIGHT need to be replaced. Best bet is to take it to either Sony or a TV/Game shop in your area to have it fixed up. If you're very experienced with electronics work, you can also look up FAQs on how to change the laser yourself. You can get a new one on eBay for around $8 or $9.
Above all, try the SIMPLEST and safest things first. And PLEASE don't go rooting around inside your PS2 unless you're well informed on the task at hand and very experienced at working with electronics. You could permanently damage the console if you're not.
Also, You WILL VOID your warranty if you open the case at all.
Good luck! =)
Dec 31, 2008 | Sony PlayStation 2 (PS2) Console
No screen or sound after loading
make sure that the memory card is in straight and all the way clean the copper connections and and make sure the memory card port on the console is clear of dirt and dust to ensure data is exchanged properly. use a lens cleaner for disk players and computers ect. and clean the lens with it because sometimes the console might not read the game correctly and load data wrong. make sure your data on your memory its not corrupt it can still be corrupt sometimes even if it doesn't say it is if nothing here helps i would just start over and make a new save game file. :)
May 31, 2008 | Sony PlayStation 2 (PS2) Console
Properties in gta vice city game
This link has more FAQs for GTA:Vice City than you could imagine. Everything you ever wanted to know will be here:
http://www.gamefaqs.com/console/ps2/game/561545.html
-John
Oct 02, 2007 | Nintendo Game Boy Color Console
GTA: Vice City loading problem
Could be corrupted, try copying the second save on a different memory card, if that works, then it's your memory card, if it still goes black the file is corrupted.
Aug 24, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
