Question about Uniden BC245XLT Handheld Scanner
I have got a used bearcat trunk tracker 3 and i am wondering how to unlock the keypad , it has a small key blinking in lower right corner
  • 454 Answers
Take a look at radioreference dot com. Search for similar problems, or join up and post your problem there.
Posted on Oct 11, 2010
How do you open trunk if battery is dead
Use your ignition key to unlock the boot (trunk) by inserting it into a small keyhole under the chrome lift on trunk lid. It took me a while to figure it out when I first purchased my jag.
Jun 15, 2014 | 2001 Jaguar S-Type
Turn signal & flashers stopped working on '95 geo tracker 2wd, 5 speed.
old post 95 tracker.
ALL four corners dead and dash (warn lamp dead) in cluster
do you hear i flash, click click????
first is fuses, but there are 2 .
http://www.fixkick.com/power-elect/95%20electrics/all-lamps95b.pdf
page 2 see that.
are the 2 blink/has fuses good. test good not just LOOK good
after all if a feed is shorted you will blow both. (tested)
the blinker module ,usually dont fail
its electronic and robust.
fuses good, then
the black wire ground cut or rusty a body
G200 it uses, and if bad usually kills the engine.
yellow-white must be 12vdc blinks on. key on
switch is bad. i bet this is ok
the relay green is OUTPUT
if the blinker has power it clicks
if it green wire flashes with test lamp the blinker module is good
if the output of the blinker switch is dead L and right
the switch is bad.
assumes both left and right sides not shorted. to ground.
Feb 16, 2014 | 1995 Geo Tracker
Can i use a slim jim on my bmw
I have a 1992 bmw 318is and when my hubby locked the doors and put my keys in the trunk it locked also! we tried everything and he was going to break a window to get in! so I had to get my back wing window open so I could get a small child to fit in it we tried to unlock it from the inside! but it would unlock then locked right back up! we had to lower the back seat and climb into the trunk and get the keys to unlock the doors from the outside to get the child out! so if you lock anything or any one in there you will need a key to unlock it! I might try calling a bmw dealer to see what your option would be! needless to say my hubby gives me my keys when we get out of my bmw from now on!
Nov 02, 2012 | Cars & Trucks
How do I unlock. Keypad or reset unit Unidentified trunktracker lll bc346xt
Press the key at the lower-left corner of the keypad (the one with the key icon just below it). If you need a manual, you may download a copy here.
Oct 31, 2012 | Cell Phones
How to unlock keypad uniden bc346xt
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
How do i unlock my e63 nokia?
its easy
only 1- press on up right botton
2- press on down right botton
that's all
Mar 09, 2009 | Nokia E63 Cell Phone
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
BC245XLT trunk tracker II
Hello majorhart, I have never owned this model scanner, but by looking at the owners manual I see there is a keylock, which locks the keypad.
If you need a copy of the manual, go here and download.
http://www.uniden.com/pdf/BC245XLTom.pdf
I hope this helps out with what you were looking for,,Mechanc.
Oct 17, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC245XLT Handheld Scanner Logo
136 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
