Question about Sony KP-57WS500 57" Rear Projection Television
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
  • Sony Master
  • 8,457 Answers
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Posted on Oct 11, 2010
Testimonial: "gave a quick and helpful answer. thanks."
I dropped my camera and hit the lens and now auto focus does not work
You'll probably need a professional repair. Compare the cost of repair with the cost of replacement. On that lens it could be about the same.
Dec 17, 2012 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 | Cameras
Prints small wavy cyan lines about one inch apart horizontally about 6" down the page. They are on the belt as well. Will just replacing the Cyan toner fix it? How can I safely clean off the belt...
Try to remove supplies and clean the printheads. If this doesn't resolve the issue, you may need to replace the color photodevelopers.
I suggest you contact Lexmark Technical Support for further assistance.
Oct 23, 2011 | Lexmark C912dn Led Printer
It doesn't allow me to take a shot. On a lense itself, there are two settings A and M. When it it is on M it takes a blurry shot, but on A setting doesn't allow. Please, help me.
M means Manual Focus. If you set the lens to this then you need to turn the lens manually to get it into focus.
A means Auto Focus and when the lens is det to this it should focus automatically but you need to set the mode button OFF Manual. It should work on any other setting.
Jul 05, 2011 | Cameras
Our Canon EOS Rebel XSi no longer works on auto focus. The flash works but the camera just makes clicking noises and the screen says "busy". Any suggestions? The camera works fine in manual...
Optical focus relies on a gear driven motorized system to focus the lens. It sounds like the drive is either frozen by a foreign object (it doesn't take much) has gotten into the system, or a tooth has worn/broken on the gearing.
Try taking the lens off and blowing the camera out with some canned air. If that doesn't do it, it's a trip to the repair center.
Jul 04, 2011 | Canon EOS Rebel XSi Digital Camera
Hi Ref: Digital Camera - Pentax K200 model It keeps auto focusing when in manual mode. Regards Chris
Putting the camera in manual mode still doesn't change the focus routine. If you want manual focus, there is a switch near the lens on the left allowing AF (auto focus) and MF(manual focus).
May 01, 2011 | Pentax K200D Body only Digital Camera
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Color separation
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 03, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
722 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
