Question about Brother XL-5340 Mechanical Sewing Machine
Bobbin thread too loose makes loops and the top thread easily pulls out
  • Brother Master
  • 7,365 Answers
Try adjusting the top thread tension & see if that solves the problem
Posted on Oct 12, 2010
When I sew, the stitching is loose with large loops on the underside of the fabric making the bobbin thread slide out easily. How do I fix that?
Lift the pressue foot off the fabric. Hold the thread spool with one hand and lightly pull the thread hanging out the back of the needle. This should seat the tread into your top tension discs properly. Now try sewing again. If it still throws loops, you either do not have your machine threaded correctly or your tension on top is set to zero.
Sep 01, 2014 | Bernina Sewing Machines
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
The top stitch is perfect but underneath the material there are many loops. I am assuming this is from the bobbin. How do I correct this?
no, more likely your top tension is too loose causing the loops on the underside of your fabric, loops on top would be bobbin too loose. raise presser foot and rethread top thdead pulling thread into tension fully. set top tension dial to 5 and test sew. if still looping underneath try tightening top tension by turning dial up to 6. but usually top tension should only need minor adjustment tweeks. you can test top tension by lowering pressure foot to engage tension and holding thread just above needle thread guide, pulling thread downwards . there should be resistence on it to your pull. if you cant feel any then tension device may be faulty, and require service.
Jun 25, 2011 | Sewing Machines
Bought used--trying it out---top stitching is
Check to make sure that the thread running between the tension disks. A quick check is to lower the presser foot and then pull on the top thread. If you do not feel any tension, then it may not be ran in between the disks. Also, check to see if your bobbin is inserted correctly going counter-clockwise. This can cause the "loose" loops and thread jams in the bobbin casing.
Feb 10, 2010 | Singer 5050 Mechanical Sewing Machine
Loose bottom stitch on brother se 350
Hi, general rule of thumb:: loops on the top, problem on the bottom.. Loops on the bottom, problem is on the top.. When threading your machine, stop just before you thread your needle, put the presser foot down. Try pulling the thread. If it pulls easily, the thread is not thru the tension wheel right. If it pulls hard, you got it right.
May 12, 2009 | Brother XL-5700 Mechanical Sewing Machine
Bottom thread is looping.
If the thread is looping on the bottom, then your problem is on the top. Pull the thread out of the needle and and put the presser foot down. If the thread pulls thru easily, then you need to rethread your machine making sure the thread is thru the top tension wheel correctly.
Rule of thumb::
Loops on the bottom, Problem on the top
Loops on the top, problem on the bottom.
Apr 26, 2009 | Brother SE-270D Computerized Sewing...
Cannot get tension balance correct
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
Apr 16, 2009 | Consew 199R-1A Sewing Machine
I have the Brother ls2125i and LOVE the machine...in the middle of sewing, it started making very big loops on the bottom stitch and they do not catch the thread from the needle. Is it the tension?...
Here are some things to try:
Big loops are actually easier to solve usually. 1st know this: Loops on bottom means the top is too loose or the bottom is too tight. With loops that big its probably the top is too loose. 1st look in tension disks, there is likely a chunk of thread in there. A toothpick is handy to dig it out (the flat kind) 2nd make sure that the thread is getting between the disks when threaded. 3rd Make sure the thread is in the take up lever (the thing that moves up and down in front and not the needle bar or any part of the needle bar.) If neither, then the bobbin case could have a burr on it and the thread is hanging on that burr. Also the bobbin case may be in wrong. I hope this helps
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension
Thread test
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no matter how much thread you pull, your thread is good. If that your machine passes that test, we can go to step 2. If not, try different spool of thread, do the same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Kent
Mar 22, 2009 | Brother LS-2125 Mechanical Sewing Machine
My bobbin thread keeps looping up on the bottom, and after adjusting the tensions both ways I can't get it to stop making a mess.
try this:
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Thread test
Step 2:
Jamming bobbin case:
If it is damaged from turning out of place once, it could have rough spots on it that makes the thread hang on it, and keeps making it turn over and over. Use a finger nail board (fine sanding) and smoothall rough spots. Then reset the bobbin case taking care to put the notch in the bobbin case in alignment with the proper spot in the machine (basically 5 o’clock) when looking at the round area where the bobbin case goes
Mar 20, 2009 | Brother LS-2125 Mechanical Sewing Machine
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
119 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
