Question about ViewSonic VG2021m LCD Monitor
My VG2021m´s sound doesn´t want to work. The mute button is off. The volume is up. And there´s still no sound.
  • 11,361 Answers
Did you varify that the sound card in the PC is working? You can try feeding the the monitor with sound source from MP3 player to see if you do get the sound OK or not, to have the sound circuits repair by the shop will not be worth it because the money will be better spent on good set of powered spekers system with better sound than the monitor built-in speakers.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Oct 11, 2010
How to un mute my macbook air?
Press the mute button again. If that doesn't work, then press the volume-up button until you can hear the popping noise of the volume adjustment.
Feb 19, 2012 | Apple MacBook Air
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
My sony vayo doesn´t switch on the sound
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Jul 11, 2010 | Sony Vaio P VGN-P530H Netbook
My volume and mute button has stopped working all other buttons are functioning properly
Press the mute button and then turn up the volume button. If no sound still then press the mute button again. If we are talking about a Remote, then change the batteries.
Apr 08, 2010 | Audio Players & Recorders
My speakers wont´t work! i plug them in and I can´t hear anything! it´s not usb !
Be sure you have the plugs in the correct holes.
Feel free to move them around. The bezels on the sound ports are often color coded and will match the plugs you have. SOMETIMES they are not and you must guess.
Also make sure your sound settings have not been accidentally set to MUTE. Turn the volume up and play some music files or anything with sound.
If these speakers use power from the household plug.
Be sure the power knob is turned on! Usually the volume button.
If no external power is supplied these usually must be turned up full blast just to hear them. Some on board sound systems do not have the power to push the these speakers very high.
If all else fails
Update and make sure the correct sound drivers are loaded for your system.
If you have another set of speakers. Try them!
Cheap doesn't matter here.
Your only trying to determine the output works.
If it works then the other speakers may be defective.
Hope this helps!
Oct 04, 2009 | Compaq Audio Players & Recorders
No sound on Powerbook G4
hey,
so not to be obvious but you have one of two problems either hardware or software. there is a way to check but you need to do a few things. first you should try creating a new user account and see if the volume problem still exists. you create a new user through system prefs/accounts. if that doesn’t work you should try a pram reset by holding down the cmd, option, r, p, key at boot. IF you have never done this before you want to hear the startup chimes at least 3 times then let the computer restart. if that still doesn’t work you should try an archive and install of the os from the discs if you still have them, and if none of that work you most likely have a hardware issue and either the logic board needs to be replaced or the speakers are bad. but either way its going to cost money if there is a hardware issue and you might consider a new computer, im just being honest.
Aug 20, 2009 | Apple PowerBook G4 Mac Notebook
Volume
re install the driver for your audio device.compaq will have the download you need
Dec 30, 2008 | Compaq Presario Notebook
No sound
Without knowing what else you?ve tried besides checking the BIOS configuration I?ll just list everything including the basics: -Check the hardware device manager and ensure your sound card shows up and is running without errors. -Make really, really sure you plugged the speakers into the right socket. -Try plugging a known working pair of headphones or other simple speaker system into your sound socket to verify your speakers work. -Open the ?sounds and audio devices? in the control panel, in the volume tab make sure the volume is mid way and not muted. -Click on the advanced button and make sure the wave, SW Synth CD Player volumes are mid way or better and not muted (the volume is the same as the previous volume slider). -Make sure your driver came from the motherboard manufacturer and you have the right one for your operating system. If you get here and it still doesn?t work then you?ll need to start considering the possibility that your motherboard may have a problem. As an alternative you can disable it in the BIOS and plug in a cheap PCI sound card. Let us know how it goes and please don?t forget to rate this post.
Mar 02, 2007 | Foxconn 661M03-G-6EL Motherboard
ViewSonic VG2021m LCD Monitor Logo
87 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
