Question about Microsoft Xbox 360 Console
No picture... when i turn on my 360 it sounds like its going to work just fine but there is no picture i can hear it boot up and i can hear the sounds when i move the cursor whith the remote but there is no picture the sceen stays black??? what can i do??
    Sergeant:
    Champion:
  • 427 Answers
I would try some of these troubleshooting steps;
  1. Make sure that the AV cables are 100% secure.
  2. Try an new AV cable.
  3. Try your console on a different TV.
  4. Call xbox customer support at 18004MYXBOX
Posted on Jun 01, 2008
Hi my problem is at first my xbox 360 went on fine then after 10 mins the screen started going fuzzy so i turned it off then back on was working fine for about half an hour then the screen started going...
If you hear sound but no picture then your graphic chip has got separated from your motherboard, this is not a simple fix. receommend you to look for a local repair shop that can handle game console repairs or send it to xbox.com
Thanks
www.1RepairStop.com
Sep 11, 2011 | Microsoft Xbox® 360 Core System Console
Picture won't come up on my xbox 360.
When it is starting up push down y and pull the right trigger the console will reastart on default settings and u it will show the picture if this dosent work try when you hear the menu screen come up. It worked for me but now i have lines going acroos hopefully you wont have tht problem
Jun 29, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont show a picture but it has sound
it might bea problem with your actual video cord that plugs into the tv.... umm my xbox has a lot of issues too but ive never had this. id suggest you let it say off for a while and try somebody elses cords that connect the xbox to the tv to see if its an issue with your xbox or if its with your cords. ill also suggest you call microsoft and they can troubleshoot...
please rate my solution :) thanks
May 31, 2009 | Microsoft Xbox 360 Console
Since your sound works, you know the xbox is booting properly.  Check two things: 1) try another television to make sure it's not the tv.  2) try another cable(from a friend?) to see if the cable is bad.
**Also, if the video settings were saved on an unsupported setting, it could cause the screen to not show video.  If you try these 2 things and you think someone might have saved bad settings, I recall a button combination you can use to reset certain things, and I try to help if it comes to that.
May 30, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no picture but sound only no red lights green ok
First take off my hard drive on the 360. Then plug it to the tv not with HDTV (use the red, yellow and white make sure it is on tv not HDTV) because it will not work for HDTV setting . then plugit into the wall with the 360 laying down not up and down and turned it on. (no picture but sound) with the 360 on take 1 towel fold it long ways and wraped it around 360 from back to front (make sure you cover the fans in the back to make it over heat.) leave your 360 on until it red rings (you can hear the 360 quit down. it takes about 15-30 mins depending on how fast it over heats. once this happens unwrap the 360 and turn it off wait 5 secs and power it back on and there you go you should have picture and sound again. if you still have problem you can now can send it to get repaired since there is a 3 year warrenty for red ringed 360's.
Feb 15, 2009 | Microsoft Xbox 360 Console
Purple "tears" on my 360 when i turn it on, no picture.
this happens when your xbox overheats. its happened to me a few times too.
rate
Feb 04, 2009 | Microsoft Xbox 360 Console
No screen on the Xbox 360
right do the towel trick it works. wrap the 360 in 2 towels and leave it on for 15 mins. then go bk to your xbox un wrap it. put it near a window if possible ( i did and its working fine) due to it being near a window you will get no overheating and its well ventilated.
Dec 14, 2008 | Microsoft Xbox 360 Console
XBOX boots up find, but no picture..NEED HELP
This has happened to me before and its a solder issue, same as Red Ring of Death issue. Try to leave the 360 on for an hour and then let cool for 5min. If this doesn't work you can try the towel method, but if that still doesn't work, the best bet is to send to Microsoft. If you do take the 360 apart, try tightening or loosening the black screws on the bottom frame, located under the x-clamps, it may take some fine tuning. You may also find that completely removing the black screws will do the trick.073dd88.jpg
Jun 03, 2008 | Microsoft Xbox 360 Console
Sound but no picture
Is the TV set to the right input?
Nov 09, 2007 | Microsoft Xbox 360 Console
Sound But No Picture
This Just happened to me. There seems to be a lot of solder issues with the 360. I bit the bullet and tried the towel trick, where you over heat the 360 for about 20 min. I Let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
70 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
