Question about Kenmore 63942 Dryer
Kenmore dryer keeps popping electrical breaker
Sounds like a there is a short somewhere.
Posted on Oct 11, 2010
  • gslm Oct 12, 2010
    dryer runs for 5 -10 minutes before tripping breaker.
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
I have a Kenmore Series 70 Dryer and it keeps blowing the main breaker on the electricity panel - the main fuse is 20 amps do i have a dryer or fuse issue ?
Your dryer needs at least a 30 amp breaker to operate correctly. Changing to a 30 amp breaker should solve your problem. Hope this helps
Sep 01, 2011 | Dryers
My Kenmore dryer runs for for ten minutes then shuts off. It also pops the circuit breaker. The drawer runs fine and then just turns off. Heats up. Lint is all clear, but don't know why it shuts off?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Either the motor gets hot and blows the breaker or if it is electric the heater element gets hot and then shorts out...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore Dryers
My dryer runs but it won't heat up to dry the clothes. It worked until my sister brought it to me yesterday. Could something have happened to it during travel?
Classic, Check your breaker box. It will be the one with the double breaker. If one side pops it will run with no heat. Rate me if I helped. I just saved you a 100 bucks or so.
Aug 26, 2010 | Kenmore 62802 Electric Dryer
Dryer keeps popping circuit breaker
either the dryer drum motor is getting tight from dry end bearings or the heating element is shorted to the dryer case or check the input terminals where power enters the unit,sometimes these ends burn off from current draw over time
Feb 02, 2010 | Dryers
Dryer trips circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Nov 21, 2009 | Kenmore 63942 Dryer
It keeps blowing the breaker
hello it sound like a bad earth check for any loose wires if ok then it could be the motor gone down to earth
shaun
Aug 31, 2009 | Kenmore Elite HE4 Electric Dryer
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Dryer won't turn on.....
Its possible that you blew out the thermal fuse on most dryers it is located on the blower wheel housing. You can test the part with an ohm meter, if has continuity its good if not it's bad.
Mar 18, 2009 | Kenmore 64722 Electric Dryer
Kenmore Ultra Care Dryer- Electric
Your dryer doesnt have a fuse. Your home breaker panel is the only protection it has..Check your circuit breaker box for a tripped breaker.
Oct 22, 2008 | Kenmore 62602 Electric Dryer
Kenmore 63942 Dryer Logo
103 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
