Question about Maytag Refrigerators
We have a Maytag refrigerator with a bottom freezer. The freezer is not getting cold. The fan is working and it makes a humming noice sometimes but all the food was melting. What could be the problem? Thanks
  • Maytag Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
My 3 year old Maytag with double doors and freezer on the bottom is making a humming noise. What is it and can it be fixed? Would the warranty cover it?
may be the comp lines and they need to be adjusted . other causes may be fan's / and some time the cold dampner can cause this . best to follow the noise till source is found then is't eas to correct .. mm
Aug 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag freezer does not work. it hums and stops
if you evap fan is not working this wouldnt produce any coldness,, or possibly it sounds like your compressor start realy is tryin to start but not working,,,
Feb 03, 2010 | Maytag MZD2665HE Side by Side Refrigerator
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Frigidaire FRS23H5AS refrigerator - freezer not cold
Humming noise would be your compressor going bad. The noise from the fan is because they are over working to try and keep everything cool
Feb 12, 2009 | Frigidaire FRS23H5AS Side by Side...
Maytag MFD2561HES Reefer not cooling
hello frooska,
kindly look at the back panel of the freezer section. if you can hear the humming sound, find out where it is coming from. if the sound is coming from the compressor, that means the evaporator fan is not running.
but, take note that u need to press the door switch of the freezer in order to check the fan. the fan stops every time the door is open. if the fan is not running, you have to remove the middle panel, above the evaporator, the fan would be there. ( in the freezer section)
but if the fan is running and the back panel of the freezer is full of frost, then that would be a defrost issue.
defrost heater, bi-metal or defrost controller.
Tnx 4 uisng Fixya,
Drcool
Dec 16, 2008 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
Dec 11, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFD2561HEQ Bottom Freezer Refrigerator - Freezer working, refrigerator not
Marc of Nc. check to make sure the fan in the freezer is operating when the compressor is on. The only thing the fresh food section gets its cool air from is the freezer. and if the fan is not operating no cold air will get up there. If the fan is running you need to make sure the air duct is not blocked with frost of the evaporator is not iced up. Check that out and get back with me if there still is a problem. Good Luck
Aug 05, 2007 | Maytag MFD2561HEQ 24.8 cu. ft. French Door...
Refrigerators Logo
60 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
