Question about Poulan ES350 16" Chain Saw
My chainsaw just stopped,mid cut and won't re-start.it's getting spark and i can smell the gas but the sparkplug seems quite dry no matter how much i pump and choke.i don't think the gas is getting through the carb,clogged? so it's about 14 months old,i don't think i have the bill but it's probably not covered under warranty anymore is it? so i live in toronto(canada) where should i take it to be seviced? it's only worked about 8 hours in 14 months how much should i spend to fix it?
  • 14 Answers
SOURCE: Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
  • 22 Answers
SOURCE: I have a Poulan 2000 chainsaw. I changed to
If this saw has a primer make sure lines are connected properly. Check for the wire going to stop switch is not pinched and grounding out. If carb. was disassembled be sure that gaskets and diaphragms are in the right order. Diaphragm with 2 flapper valve should be closest to carb body and diaphragm with metal disk should be installed after gasket is installed against carb body. I am assuming that saw was running before this cleaning. If not remove muffler and look for vertical scratches on piston this would indicate a scored piston.
Posted on Jan 16, 2010
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
dontbother10
  • 2220 Answers
SOURCE: floods out everytime you try to start no matter
Clean the air filter. Clean the spark arrester (muffler - if it cannot exhale it cannot inhale). You can prime until your thumb bleeds - that is NOT the problem. To much choke almost always is. It is severely flooded Open and follow this BE CAREFUL - Extreme fire hazard.
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
I am going to make the following assumptions:
1. It is a Poulan PP4218(WeDoNotCare), start procedure the same.
2. You removed and verified there is spark (plug replacement recommended). The plug is dry (not flooded).
3. With the saw at waist height; the starter handle held; and the saw released. It remains against the starter handle or VERY slowly lowers with a distinctive pause during each compression stroke.
OM follows:
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2004/NOUS2004_530165555-01.pdf
All Poulan CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
It needs spark, fuel, and compression to run.
An overly rich mixture should not keep it from starting.
To much or to little fuel will (most start problems)!
The start procedures are on pages 9 and 10.
STARTING A COLD ENGINE
If the engine is cold - Please read the second NOTE: before trying to start.
If warm – read the DIFFICULT STARTING (or starting a flooded engine). I would try it with choke closed first (Pull to full choke; push to off choke). Hard starting is almost always flooded on a 2-cycle engine. You can prime all you like; priming does not inject the fuel mix into the carburetor. It circulates mix from the fuel tank through the carburetor and returns any excess to the tank
Reply below with what happens. I will help you as much as I possibly can. HTH
Lou
Posted on Feb 04, 2010
  • 4088 Answers
SOURCE: poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Posted on Feb 24, 2010
Have now replaced sparkplug , spark module , checked for spark , took spark plug out put small amount of fuel in hole dipped spark plug in fuel replaced tried to start and nothing not even a pop how i
If it has been sitting a while then the gas lines may have gotten brittle and broken inside the gas tank. Look in there with a flashlight. Dipping the spark plug in fuel wouldn't nessesarily work.
Mar 12, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
40 CC WILD THING POULAN
maybe the thermal sensor in the engine is overheated..it is inthere to keep the engine from frying.
Oct 23, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Went to start my XL500 homelite chainsaw and the rope won't pull out.It worked fine when I ran it dry for storage, now it seems like th sprocket won't turn. looks like chain oil is comming out
If it is bar oil then the gasket is leaking between the oil tank and the crankcase, this would mean a full strip down and replace the gasket.
Feb 10, 2013 | Garden
My cutoff saw won't start, compression is good, has oil/gas mix, gets spark from wire but sparkplug was dirty so i cleaned it and she still won't turn over
If the saw briefly runs when you prime the carb and/or cylinder with gas then most likely fuel is not getting thru the carb. Try rebuilding the carb and replacing the fuel filter first. You can also search on youtube and google for troubleshooting tips.
Jun 03, 2012 | Homelite Xl-98a, Xl-98c, Xl98-d, Xl98-e...
Poulan Pro - won't start after quitting
Hi, unfortunatley you have partially siezed the chainsaw. You will still feel some compression with your thumb but the rings will be siezed in the piston. Hence no fuel transfer to the sparkplug. Sorry Phil.
May 30, 2012 | Poulan Garden
Homelite 14inch chainsaw
Open the gas tank then reach something inside the tank. You will feel a small fuel line in there. Try to fish out the loose end of the line and you'll find a fuel filter on the end of it. Clean it or replace it and then try to start it again.
Sep 12, 2009 | Homelite ZR10926 16 Chain Saw
Ran lumpy whilst cold then stopped. Won't start. Sparkplug good but is dry. Can smell fuel at the exhaust when engine is turned over...
Sparkplug good? gas at exhaust indicates unburt fuel.Try taking oof sparkplug wire and holding to ground metal (not Painted) on bike, do you see a spark?Dry plugs? all Plugs?Check , Coil, Lumpy sounds like dry cracked sparkplug wires.With all Combustion Engines it's either Gas or Spark investigate.Good Luck.
Sep 05, 2009 | 2007 Aprilia Pegaso 650 Trail
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not start.got gas and spark.loosenthe gas cap firer but would not stay running.thank you.
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Aug 13, 2009 | Poulan Garden
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Jul 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan ES350 16" Chain Saw Logo
108 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
