I have a Dimplex Sleepsafe Electric blanket and it has just stopped working for no apparent reason. I note that in your instruction leaflet it states that heavy bedding may cause the PROTECTION SYSTEM to permanently disconnect power. This may have happened in my case but how permanent is "permanent" does that may mean that it will never work again? It is a lovely.comfortable electric blanket with a fleezy top (the best I've had) and I dont't want to just throw it away. Can electric blankets be repaired? Your advise would be appreciated. Thank you.
SOURCE: Electric blanket
Sometimes you can buy the controls on ebay. It is cheaper. Otherwise buy the controls here: http://biddefordblankets.com/
Posted on Apr 02, 2008
brainyass
  • 242 Answers
SOURCE: morphy richards electric blanket - how to use timer setting
Go here and pick your model for instructions:
http://www.morphyrichards.co.uk/DownloadSearchResults.aspx?G1=G19
Posted on Oct 24, 2008
SOURCE: My Sunbeam electric blanket controls
Same problem, but now it is ok.  I emailed Sunbeam and was told that if my blanket was not plugged directly into a wall outlet it was not getting enough power and I needed to plug it into a wall outlet taking these steps:
1) Unplug from the surge protector/extension cord 2) Unplug from the blanket 3) Plug back into the blanket 4) Plug into a wall outlet
Posted on Dec 22, 2008
SOURCE: electric blanket does not warm
Call the manufacturer. They will often do repair for free.
Posted on Dec 31, 2008
SOURCE: Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Posted on Feb 22, 2009
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
I wish to find a copy of an instruction manual for a Dimplex portable Evaporativeair conditioner - model Deva -13
Here's a link in pdf format for the owners manual for a DEVA-13 Dimplex Heater.
http://www.glendimplexdealer.com.au/Resource1049853HJDUFOS023X/Owners%20Manuals/Cooling/DEVA-13_IML.pdf
If the link doesn't work when you click on it, copy and paste it into your web browser.
Jan 18, 2011 | Dimplex DEC1000H Electric Heater
Dimplex SHB20 Sherbourne Electric Stove -Flame Effect not working
Call Dimplex : 1-800-668-6663 ext: 358 they are kind and very helpful, they will send you arts to repair.
Jan 10, 2009 | Dimplex Compact Electric Flame Stove...
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
Every thing on heater quit working,
Go to: www.dimplex.com
1. click customer support,
2. click technical support documents
3. click parts & services
4. click on your model stove
Your operations manual will appear with instructions on how to repair (11 pages long.)
Dec 08, 2008 | Dimplex Compact Electric Flame Stove...
ELECTRIC FIREPLACE ONLY 1+ YEARS OLD HEAT STOPPED WORKING ONLY?
The heater will not work if either the thermostat or blower are not working. (or the heater element is bad). Most of the time with these electric heaters, it's the thermostat.
http://extranet.dimplex.com/files/domain4103//DS5598%20DS5603%20DS5804%20PARTS%20&%20SERVICE%20MANUAL%20REV00.pdf
page 6 has a list of the parts
Feb 02, 2008 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
