Question about Conair CID 100 Conairphone
My cid110 callerid phone does not ring. works well otherwise. thanks m j.
We had a power outage, main system box making sound like a rotary phone when I dial.
The battery in your phone system is dead. This will happen every time you have a power failure. Everything resets. Date becomes Jan 1st 1980 (but might update if you have callerID), all phones will have access to only line 1 and line 2, both those lines will ring on all calls, and the line settings are set back to pulse ...
Ideally you either have the battery replaced (it's soldered on the board of the system), or you get a new phone system. Otherwise you'll have to reprogram everything when you have a power failure.
Jason the phone guy
May 10, 2011 | Nortel Meridian M7208 Corded Phone
Hello, I'm trying to turn the ringer off some of the phones at my work. We have panasonic kx-t7630 phones. Are you able to help me please?
When you bought the phone system, it was either installed by a professional installer, or you got some sort of instructions. A Panasonic phone system of the TDA/TDE/NCP type rings phones by Incoming Call Distribution Groups (ICD). The main group is 1 and usually is numbered 601. Extensions are members of an ICD group(s) and the number of rings can be programmed for No Ring, Immediate ring, or delayed rings of 1-6.
You can turn off the ringing, but keep in mind that CallerID only displays on a ringing phone or after you answer it. So, if you somehow have access to program 620 and 621, then you can change it from a phone, if not, you'll need access to the maintenance console of your particular phone system.
I don't wish navigating in 620/621 from a phone on my worst enemy and it's beyond the scope of a free forum to instruct you on how it works. I suggest you call your Panasonic service tech.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
I have a ATT 974 phone and callerid is not working on the phone? any suggestions.
Disconnect battery and power cord. Then plug back in. See if this works.
Feb 09, 2010 | AT&T ATT-974 Corded Phone
How do you activate callerid?
The line must appear and ring for the caller ID information to pass to the extension before you pick up.
IF you are fmiliar with programming:
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
IF YOU ARE NOT FAMILIAR WITH PROGRAMMING, call in a vendor as you can mess up your system
Nov 06, 2008 | NorStar T7316E Corded Phone
Onetel cordless phone OT350 does not ring
Hi I had a similar problem with my 350, I phoned their support line who said it was not repairable so if you found a solution please let me know?
Aug 29, 2008 | Lands Phones
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
Will not ring
Had the same trouble reset the phone to defaults and do not register handset. Enter the area code and program the ringer volume. Use the PROG (MUTE PROG) key & the CALLERID-VOLUME buttons to make selections in the menu on the screen. to save the setting press the PROG key.
Jan 31, 2007 | GE 28021EE2 Phone
Conair CID 100 Conairphone Logo
66 people viewed this question
Top Conair Lands Phones Experts
k24674
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
