Question about LG LFX25960ST Stainless Steel French Door Refrigerator
My ice maker for my lfx25960st stopped working. The lights on the side to indicate ice cube size do not come on as though the ice maker isn't getting power. there is ice in the tray but it does not empty it. the bar is not stuck. please help. Thanks.
SOURCE: Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I am a service tech and see this problem often , whats happning is every time you open the left door when water has not frozen. the water splashes into the icemaker and freezes, the only fixto the prolem i have found is to replace icemaker, i have found if you try to thaw out you might get one tray of ice out. thanks
Posted on Jan 13, 2008
  • 489 Answers
SOURCE: Ice Maker Freezing Up and Ice not dispensing
Sounds like the water valve has a small leak and continuously drips water onto the icemaker.  Have the water valve checked and if necessary, replaced.
Posted on Apr 27, 2008
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Posted on Sep 06, 2008
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Posted on Apr 28, 2009
  • 358 Answers
SOURCE: Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
Posted on May 02, 2009
Ice maker stopped working. The cubes gradually got smaller until it just stopped producing cubes
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iot47
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
I've got the LFX25960ST model. The icemaker
its the ice maker .water or condensation has built up in the ice maker modual and refroze upon turning unit back on.either get a new ice maker or uninstall the ice maker and let it dry for a few days and reinstall.but it could happen again that way.or maybe not.
Jul 24, 2009 | LG LFX25960 Bottom Freezer French Door...
Icemaker does not work
Does your unit have the cube size selection button inside of the ice maker door , if so is it lit up, if so is it on a cube selection. If not that is the reason the ice maker is not working because even though the unit is on the cube selection has not been made. This should solve your problem.
Jul 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
LFX25960ST Ice Maker Shutoff Arm
Unplug the ice maker from the fridge. You will see the plug by following the wired coming from the ice maker. Leave it sit for 20 mins. Plug it back in and hold the green ice cube size button in and watch for the ejector fingers begin to move. If they move they will go around to about 11 o'clock or so and the water should come on filling the tray. If any of these things don't happen, you have a bad ice maker.
Jun 12, 2009 | LG LFX25960ST Stainless Steel French Door...
LG Ice maker
I got the same problem where the plate is cold and the water does not fill - saw this comment from other posting and help. Basically, the ice maker was stalled! Make sure you can see the green light is on, which means you have power. if its lit, press and hold the cube size button until i/m starts to cycle. If i/m runs, but does not fill then your water valve is bad. If i/m will not start then your i/m is at fault.
Dec 05, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice Cube Maker
Here is a link for the srevice manual ( section 7 discusses how to troubleshoot an ice maker ) that should get you going..
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Hope this helps you...
Sep 14, 2008 | LG LFX25960ST Stainless Steel French Door...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice in the gears.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
41 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
