If your refrigerator's ice maker is working, but no ice is dispensing through the dispenser, there are a few possible causes and troubleshooting steps you can try:
Check the ice chute: Make sure the ice chute is clear of any ice obstructions. Sometimes, ice can get stuck in the chute, blocking the flow of ice to the dispenser. Use a plastic utensil or a straw to clear any ice buildup or debris in the chute.
Inspect the dispenser mechanism: Open the dispenser area and check if any part of the mechanism is obstructed or damaged. Look for any ice blockages or misaligned parts that may be preventing ice from being dispensed properly. Clean or repair any issues you identify.
Verify the dispenser solenoid: The ice dispenser is usually operated by a solenoid that controls the release of ice from the ice maker. Ensure the solenoid is functioning correctly by listening for a clicking sound when you press the ice dispenser paddle. If you don't hear a click, the solenoid may be faulty and require replacement.
Check the dispenser motor: The dispenser motor is responsible for activating the auger that pushes ice through the chute. If the motor is not functioning properly, it may need to be replaced. Test the motor by activating the ice dispenser and listening for any humming or buzzing sounds. If you hear the sound but the auger is not turning, the motor may be faulty.
Inspect the ice bucket: Ensure that the ice bucket is properly installed and seated in the correct position. Sometimes, if the bucket is not aligned correctly, it can prevent ice from flowing through the dispenser. Remove the ice bucket and reposition it securely.
Check the water supply: Make sure the refrigerator has a steady water supply. If the water supply is interrupted or the water filter is clogged, it can affect the ice production and dispenser functionality. Check the water line and replace the water filter if necessary
Andrea, make sure you are getting water to your ice maker. Most common ice maker problems are caused by lack of water. There is a water valve( dual) that feeds your water dispenser and ice maker that could be the culprit. Even if you are getting water out the door the valve can still be bad( separate water lines)..
Second thing to check are your optics( It measures ice level in your bin. If they are defective it will trick your ice maker into thinking its full of ice and not produce anymore.) They are located on the freezer walls just below ice maker..
I have found that my ice maker makes ice, but i can not dispense, water or ice, control board good, micro switch good only thing left is reversing solenoid. i have just ordered one once i replace it ill get back to you
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Problems with Ice Maker/Water Dispenser If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
