Question about Dewalt D51850 Heavy Duty 20 Degree Full Round Head Framing Nailer
How do i replace a trigger valve assembly for a d51845?
  • Dewalt Master
  • 7,733 Answers
Put air on my D51844 it starts firing nail out i have not touch the trigger what is the problem danger
Dewalt uses a combination buna and vinyl orings. The vinyl orings in their nailers fail by turning into putty. To fix your problem replace the trigger valve or the vinyl orings within. You will meed three orings in the trigger valve, (buna 70) , two rings are 2mm and one is 6mm. Within the body of the gun there are 5 more vinyl orings that fail. The rebuild kit has some vinyl orings and will most likely fail also. Convert to buna for longer life. Good luck
Apr 25, 2016 | Dewalt Round Head Framing Nailer D51845
My DeWalt D51845 - when you use the sequential trigger it shoots maybe every 4th time you pull the trigger. If you replace the sequential with the bump trigger ever 3rd one shoots 2 nails.
Check this notice and post your question again if you nailer is not part of this recall. Good luck.
D51844 & D51845 Recall Notice Published 06/09/2005 08:49 AM ' Updated 09/29/2011 09:35 AM What is the recall on the D51844 and D51845 about? The contact trip on some of the nailers may not operate properly, which may permit a nail to be ejected with only trigger actuation.
Only nailers with the following date codes are affected:
200203, 200204, 200217, 200302, 200304, 200308, 200315, 200325, 200329, 200343, 200403, 200404, 200406, 200407, 200412, 200413, 200415, 200416, 200417
See the link listed below for illustrations & more information regarding the recall.
http://www.dewalt.com/us/articles/article.asp?ID=1373
Oct 16, 2011 | Dewalt Round Head Framing Nailer D51845
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
I have a Stanley Bostitch N80SB with the sequential trip kit. I have installed a new trigger valve assembly, and the unit now holds air pressure, but the trigger will not activate the plunger. I can...
The safety foot assembly pushes up on inner trigger lever which in turn pushes on the trigger valve. If the trigger valve firing pin is slightly shorter than the old trigger valve, or the inner lever is worn from use, the inner lever will not push the trigger pin all the way in. Examine the trigger and the roll pin that holds the trigger for wear and check that the safety is pushing up on the inner lever. If the trigger is worn replace or repair with metal type epoxy filling in worn spots and use a new roll pin.
Aug 18, 2011 | Stanley Air Tools & Compressors
Miss firing you have to place it on an angle to get it to shoot
Dewalt has a new trigger valve to replace the original (part number 5140095-73). Not sure if the new valve is replacement to address an issue or natural progression. I would also replace the orings that make contact with the reference #55 on parts list called the bulkhead. There are four orings contacting the bulkhead that wear and may contribute to multi-fire or miss. Finally, look for worn parts that contact the trigger. The safety foot pushes up on the inner part of trigger then pushes on the firing valve pin. If safety mech parts are worn or trigger is worn, the gun may miss. Parts are at dewalt service center or at www.toolpartsdirect.com Good luck
Aug 09, 2011 | Dewalt Round Head Framing Nailer D51845
Bostitch N79WW Leaking air from the trigger. Can't figure out how to remove trigger assembly. I removed two pins, one at the trigger hinge and one lower pin for what appears to be for the valve assembly,...
See the link below for a parts breakdown of the gun. Usually this problem is a defective trigger assembly and requires that the trigger be replaced. You can also check the Orings. If there is an air leak this can also occur.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Oct 29, 2010 | Bosch Air Tools & Compressors
As soon as air hose is connected the firing rod extends, stayes extended, and air continues to come out the vent holes at the top of the gun. this problem started after i replaced all the o-rings and...
check for a stuck firing valve or pinched o ring in the cap area, usually this is caused by the trigger valve but look in the cap, Did you lube all the o rings before installing??
Sep 30, 2010 | Dewalt Round Head Framing Nailer D51845
My dewalt framing nail gun was hooked to the air compressor, but was not being used when it began leaking air which you could hear and got louder. It sounded like it was leaking around the trigger area....
There are O-ring seals around the trigger that are probably leaking. You can try to lubricate the gun by adding the pneumatic oil to the air supply. That may be enough to seal it back up. Otherwise the seals and/or the trigger assembly will need to be replaced.
Dan
Mar 29, 2010 | Dewalt Round Head Framing Nailer D51845
Press the trigger and all we get is a puff of air
could be driver stuck with jammed nail or the firing valve is stuck in the head. If this is a Dewalt tool go to Dewaltservicenet.com and type in your model number for a breakdown before removing the cap.
Nov 08, 2009 | Dewalt Round Head Framing Nailer D51845
Air leaks arond trigger when depressed, but no nail fires.
Where does the air leak out from? If it leaks from the trigger DeWalt makes a trigger valve assembly part # 641006-00 list 8.89 BUT if it leaks from other areas we have to look into it deeper. If it is just the trigger valve let me know and I will give you instructions how to remove and install the new one.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Dewalt D51850 Heavy Duty 20 Degree Full Round Head Framing Nailer Logo
139 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
