Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9100 LW1 Front Loading
Just a follow up. When water was entering the machine, a high pitched buzz was coming from the water inlet valve. When the repair man was checking the problem, he unplugged a wire to the inlet valve and the noise stopped. He therefore came to the conclusion that the problem was the inlet valve. The hoses and water pressure are fine. Do you think he made a correct diagnosis?
Thanks
  • Anonymous Mar 16, 2014
    no hot water comes in
  • Anonymous Mar 25, 2014
    Seems like obstruction
  • 5,911 Answers
Probably a good assessment. I wasn't trying to second guess your repairman. I just wanted to make sure you were able to have the knowledge to eliminate some of the possibilities yourself. That way, you feel a little more confident that you're getting the correct repair. It sounds like the solenoid is probably clogged or scaled up from sediment. Let me know how things turn out for you.
Posted on Jun 01, 2008
Cold water does not enter the Whirlpool Duet front loading washer (Model: GHW9150)
There are two solenoids back where the water enters the machine ( probably an ugly blue color). Possibly the Cold water solenoid failed or the wire feeding the solenoid fell off. Google Washing Machine Solenoid and you can see what it looks like. The Water hoses literally attach to it
Dec 12, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer estimated time remaining flashes h followed by f
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nov 29, 2012 | Whirlpool Washing Machines
I need a parts manual for a whirlpool front loader washing machine
Please go to the following link and download the manual. It is for GHW9100 and quite exhaustive showing all the pars and their assembly.
http://applianceassistant.com/pdf/duet.pdf
Sep 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Just want to know cubic feet of the whirlpool ghw9100
The volume capacity of Whirlpool Duet GHW9100 is 3.7 cubic feet. Refer to the specifications below for other details.
Jul 19, 2011 | Whirlpool GHW9100L Front Load Washer
I own a whirlpool duet ghw9100 lw1 and i have two problems...fabric softener wont dispense and the drum fills and overfows with water on occasion
The overfilling problem is due to the water valve allowing water to slowly seep into the machine when not in use. You simply need to replace the water valve. The first thing to do for the fabric softener is to clean the dispenser. Failing that you can remove the top of the machine to observe the correct movement of the zone valve for the dispenser.
Jan 11, 2011 | Whirlpool GHW9100L Front Load Washer
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
It could very well be a water inlet valve, but there are several other things that may cause your problem. Please read the information I have about the "FH" error on the following link:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
As you can see, you may need to rule out some other possibilities. Did your service man check all the other options? The easiest things you need to check is to make sure you don't have a siphoning issue, something clogged in the drain pump or lines, and dirty water inlet screens. These are the more common contributors to this problem. The pressure switch and flowmeter are less likely, but still should be checked. If need further assistance, please go to my profile and use the "Ask Me" feature for a quicker response. I hope this sheds some light on the problem and helps resolve it for you.
May 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
prem mathew
