Question about Microsoft Windows XP Professional
Error code 0x80070071 during xp clean install
    New Friend:
  • 4 Answers
If you are facing windows update error 0x80070017 then don't get worried follow the given below steps to fix this error:-
·You have rename the download folder and to do this you have to open notepad and then copy the commands
net stop wuauserv
CD %systemroot%\SoftwareDistribution
Ren Download Download.old
net start wuauserv
    ·And then paste it in the notepad then go to the file menu of the notepad to save it by clicking on save as tab.
    ·When you click on save as then it will ask you the file name then name it as rename.bat and then save it to your desktop.
    ·Then double click this rename.bat file to register the windows updates files.
    ·Then again try to install updates. When the updates are successful then delete the rename.bat folder. By the way you can also use third party repair tool to fix this error.
fix windows7 error
Posted on Jun 13, 2014
  • Microsoft Master
  • 20,318 Answers
Found this after I had the same problem
The error code of 0x80070017 means it can't read the dvd. The good news is that you can fix it with little trouble. First of all, the only reason you have this error is if you downloaded the iso, legally or otherwise. I have been searching for the answer to this question for about 20 minutes with many different answers. After weeding out the ******** solutions, there is one that will work. . .
You have to reburn the iso at a slower speed. You will get much better results if you burn the dvd with the same drive that you will install it on. Perhaps Microsoft did this on purpose? If that doesn't work, try a different burn application. If that STILL doesn't work, get better media or actually buy the OS. :)
This error code and fix applies to Windows 7 installs as well.
Posted on Oct 11, 2010
  • Connie Armstrong Oct 12, 2010
    I did buy this OS....don't know how to make a bootable cd. Wish I did. Thank you for your help. I think I have narrowed it down to an installer error.
  • Andrew Taylor
    Andrew Taylor Oct 12, 2010
    OK, if it is an original disk, the problem is your DVD/CD ROM. You can try cleaning the optics with a CD cleaner disk and if that doesn't work you will need a replacement DVD/CD unit for the computer. This is exactly what happened to me and with a new burner in the computer the OS loaded first time.
Error code 6be showing wen installing winxp
This error can occur due to any of the following:
The Catroot2 folder is not correctly deleted during the installation.
The random access memory (RAM) configuration is not compatible with Windows XP.
One or more of the RAM modules on your computer do not work correctly.
Nov 09, 2013 | Microsoft Windows XP Professional
I can not install operating system(error code 4 and code 7)
error code 4 -- try resetting the ram chips
error code 7 -- Your error is probably because there is a problem reading the CD. Make sure your CD is clean, and try a cleaning the laser lens in the CD drive with a laser lens cleaning CD.
Oct 09, 2009 | Microsoft Windows XP Professional
Computer will reboot on Virus/Spyware scan at random. I have: 1. Installed clean XP SP2 parallel system and booted that one. Same problem. 2. Memory Test at boot time is OK. 3. Air circulation from Power...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
Sep 18, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
Error during babel initialisation during execution of bad boys 2
Everyone, I have found the solution to this. The simple thing is this game was never made to run on Windows Vista or above.
You can fix this easily though - go to your desktop and you should see the Bad Boys II launcher, right click and then go to properties. Then click on the compatibility tab and tick the box that says "Run this program in compatibility mode" and choose Windows XP.
Problem solved, if you want to thank me visit, daily-porn.co.uk to make some easy money.
Mar 31, 2009 | Video Game Consoles & Games
System cann't take/set up windows-xp
I would suggest when you start the install of XP, chose to re-format you hard drive for a clean install. The Vista files need to be erased completely before XP will install on the drive. If you can, I would use fdisk first and then install XP. Let us know how it goes from here.
Feb 02, 2009 | Computers & Internet
Stop error
Visit this post on microsoft to resolve your problem.Your RAM may be the cause of the error.
Aug 22, 2008 | Microsoft Windows XP Professional With...
Web Camera installation
Code 28
problem
The drivers for this device are not installed. (Code 28). Solution: you could be having a problem with the cd u are using trying to install the drivers online
Aug 14, 2008 | Microsoft Windows XP Professional
Can't install xp
If you could give me more info as to what it's doing during the instalation, ie.. error codes, locking up, etc... I can help.
Jul 08, 2008 | Acer Aspire 5100 Notebook
XP upgrade to Vista install error code 0x800705AA
This error is something to do with the "Product Key" I think I have Googled this error and this is what shows up the most? I googled ... vista install error code 0x800705AA .... so perhaps ya can follow up in this vien... Good Luck
Feb 08, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows XP Professional Logo
544 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
