Question about Microsoft Xbox 360 Console
How could I prevent the red ring and overheating?
    Genius:
  • 1,175 Answers
Get a fan mod for the unit.
There are some that click onto the back to help the on board fans
Posted on Oct 11, 2010
How to Stop the Red Ring of Death on Xbox?
Hi Carolyn,
- notice poor game performance (if your games start taking a long time to load, or they become stutter or crash, it may be indicative of a looming hardware failure)
-notice poor system performance (if your system locks up, even when not playing games, this is a sign of hardware failing).
- understand the different light codes
Green-green lights indicate that console is powered and operating properly
1 red light-Hardware fault. Usually followed by E74 code on TV
2 red lights-overheating error. If the console becomes too hot, the system will shut down and display this light code
3 red lights-general hardware failure also known as the red ring of *****
4 red lights-AV cable isnt currently plugged in
If you do get red ring of *****:
- purchase a fix kit
-have console professionally fixed
-have console sent in to microsoft
-Prevent red ring of *****-understand what causes hardware failure
-keep your system in a well ventilated area
- avoid long gaming sessions
-keep system horizontal
-avoiding stacking items on xbox
-clean gaming area
-dust xbox
Oct 20, 2016 | Video Game Consoles & Games
Xbox keeps turning off
it usually means it is overheating and is needing air it shuts off to prevent what is called red ring which is a very common error code.
Jan 07, 2013 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
2 rings of death only when a play a video game. I had 3 red rings, then I did an x-clamp fix , cleaned GPU and CPU and applied arctic sliver to the xbox. When I start up my xbox it show no red...
Hello there
From what you have said it sounds like you have the RROD - 2 RED RINGS ERROR
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Jan 05, 2011 | Microsoft Xbox 360 Console
I am having the infamous Red Ring Of Death issue, ...
Sections 1, and 3 are flashing red
- Overheating
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
May 21, 2010 | Microsoft Xbox 360 Console
Repair XBox 360
I can help with the overheating part. There are auxillary fans made to fit right on the XBOX. Fixing the 'Ring of Death" can be very complicated, depending on what all went wrong inside.
May 31, 2009 | Microsoft Video Game Consoles & Games
2 red ring
try keeping your xbox wrapped in towels
Mar 29, 2009 | Microsoft Xbox 360 Console
Three rings of death
Your system will need the 3 red light service. The 2 red lights flashing indicates overheating. We can fix this for you if interested email for estimate
xbox360fixer@verizon.net
Thanks
Jan 13, 2009 | Microsoft Xbox 360 Console
I have to red lights after about ten mins on the xbox 360 and it?
I haven't got an Xbox Myself but I hear that the red lights mean the console has overheated and its a failsafe to prevent damage. It was something ALOT of people got. Also known by gamers as the "RRoD" Or 'Red Ring Of Death". Microsoft released an open letter giving a public warrenty extension to 3 years.... Basically send it back to where you got it under warrenty for the reason of
"General Hardware Failure" and you SHOULD reseave a new one. Sorry if this isn't what you wanted to hear.
Hope it helps!
Dec 26, 2008 | Microsoft Xbox 360 Console
Two red rings
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jul 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
14 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
