Question about Kitchen Ranges
Press the start button and dryer turns, let go and it stops. Where do I begin troubleshooting?
  • 1 more comment
  • cynthia miller Oct 12, 2010
    could it be the actual button on the control panel?
    Could it be the relay on the actual control knob (control panel)
    thanks, i'll try that this morning...i'll let you know. appreciate your assistance.
  • Kitchen Ranges Master
  • 11,800 Answers
Start by checking that the drum rotates freely - unplug it from the wall and rotate it by hand. Then check that the air exhaust and the lint separator are free/unclogged.
After that you must dismantle the dryer to check the motor of the drum, heating resistance and the fan - since you will be working with live power you should let that to a pro.
Posted on Oct 11, 2010
  • Azrael SRL Oct 12, 2010
    Actually it's a programmer, and yes, it very well it could be fried. But the only way to diagnose that with a simple multimeter is by exclusion - if all the other components are functioning then it's the one that is faulty.
Hoover Tumble Dryer VHC 391t. Its starts and does a cycle stops to turn the other way and just stops. If you press the start button it just clicks.
The most common problem for this would be the motherboard of the system that's controlling the Hoover Tumble Dryer. You will have to either get it repaired by a professional or get a new dryer.
May 14, 2012 | Hoover VHC391 T-80 Dryer
When I press the start button to begin drying clothes, once you take your finger off the button nothing happens..The dryer drum will turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 26, 2011 | Whirlpool LGB6300 Gas Dryer
Kenmore 110.6807 Dryer won't run properly. In diagnostic mode, everything checks out, Dryer runs and heats. Getting F2 error in normal and diagnostic modes. I disconnected P5 and checked the switches on...
One of the first things to do when a F2 error code appears is to perform a simple reset. To do this, turn the dryer off and disconnect power to the dryer. Wait 30 seconds to one minute, restore power and turn the dryer on. Choose a new dryer cycle and push "Start" to begin. If the error code does not return to the display, the reset was successful and no further action is necessary. Hope this helps.
Read more : http://www.ehow.com/info_12001824_kenmore-elite-dryer-troubleshooting-f2-error.html
Dec 06, 2010 | Kenmore Dryers
HELLO,
First of all put off the power from the wall carefully remove the plug from the wall if possible allow it to relax for some time them replace the plug back to the wall then put on the power supply then press the star button again.
please note if the problem remain you can easily get back to me by commenting for further explanation.
Thank you and thanks for using fixya.
Oct 11, 2010 | Kitchen Ranges
I'VE HAD MY DRYER 3 YEARS. POWER COMES ON BUT WHEN YOU PUSH START BUTTON THERE'S JUST A PAUSE AND THE ERROR CODE " F". PLEASE HELP!!
Select any one button (except POWER, START, and STOP) and follow
the steps below, using the same button (remember the button):
Press/hold
3 seconds
➔ Release for
3 seconds
➔ Press/hold
3 seconds
➔Release for
3 seconds
➔ Press/hold
3 seconds
All indicators on the console will
momentarily turn off, then turn back on with 88 displayed. After
5 seconds, the Automatic test begins.
Use the tech sheet info on page 2 as a starting point
Note to get the exact tech sheet or manual for your machine go to ServiceMatters and post your model number.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Whirlpool 110 electric dryer will not keep running
When you press the start button you complete a circuit bringing the juice into your dryer to run the motor the igniter or heating elements and what ever else goes whee when your dryer is drying. So if you press the button to complete the circuit then when you let go of the button it would stand to reason that it break that flow and shut it all down. However in a dryer there is something of a centrifugal switch that kicks in and keeps that circuit open and flowing with juice once the drum begins to turn and you let go of the button. That's why in a normal situation if you don't hold the button down long enough the dryer will cut right back off or if you open the door to the dryer to throw something in and close it before it quits turning it will stay running. Sounds like you could add this centrifugal switch to the list of possible culprits in this mystery. O7OUT
Jun 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer wont start
Your motor is bad.
Apr 19, 2009 | Dryers
Whirlpool duet dryer will not start. Panel lights come on as usual and when press start machine clicks and will not start. Light on wet sensor lights and no drying action begins.
press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly. This is a secret test and reset for your dryers control, so please keep this between us. The whirlpool people would be heart broke if they see this posted on the web ;-) . If your dryer will still not start after this test, you may need a new control. If you need a part let me know and I can ship it right to you. Good luck and I hope this will fixYa and saves you the $400.00 it would cost for whirlpool to send a certified tech to come to your home.
Mike Anderson
Anderson Appliance Repair
9865)945-3808
Dec 01, 2008 | Whirlpool GEW9200L Electric Dryer
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
