Question about RIM BlackBerry 7250
MSL password problem
I have a 7250. We have entered the programming code incorrectly too many times. I now have the code, ##000008 enter, but i get this error message "usage of programming lock code has exceeded the limit". Is there anyway to reset the command prompt? Thanks.
  • judasports Jul 19, 2008
    I bought a Blackberry 7250 from a seller who had me incorrectly manually program the phone for service. It now displays an error reference number of tries exceeded. Is this something you can fix. The display says Alltel when you turn on the phone.
  • icemn137 Feb 24, 2009
    that ##000008 code is a 1 time programming code its not the auctual spc code
5 Suggested Answers
  • 44 Answers
SOURCE: My Blackberry 7250 locked me out
If you use a BB desktop manager your in luck, you have a back up file? Keep reentering passcode and eventually your blackberry will master reset. Make sure you have the lastest software on your blackberry.
Posted on Jan 03, 2008
SOURCE: my blackberry 7290 showing "error 507"
good Days
I have problems whit my BlackBerry 7290. Wen starting it is showing "error 507". pls help me how unlock it.
post solution for me here..
thank you for help me
my regards
Posted on May 16, 2009
fleshgear
  • 541 Answers
SOURCE: "enter blackberry"
As a security feature, the BlackBerry device is designed to allow a maximum of 10 attempts by the BlackBerry device user to type the correct password. After the tenth attempt, if the correct password has not been typed, all data is erased from the BlackBerry device in order to discourage its theft or misuse.If u r a blackberry enterprise user then contact ur BES administrator and request to reset the password.If u r not a blackberry enterprise user then there is no way to have the password changed without wiping all data from your BlackBerry device.
Posted on Aug 12, 2009
asber
  • 291 Answers
SOURCE: puk code entered, but failed
well, just by the way you do it, you already know what to do, entered again your pincode if its wrong and is blocked, it will ask again for puk code, now enter your puk code, enter the new pin, don't type 0000, just type 1111, type again 1111 to confirm, then check..
good luck.
Posted on Feb 24, 2010
akhtark74
  • 85 Answers
SOURCE: Entered a password 10 times
Dear ,
First you have to re start you device .
If your problem is same as before , you have to re install OS in your BlackBerry device via desktop manager.
You can download the software :-
https://www.blackberry.com/Downloads/entry.do?code=577BCC914F9E55D5E4E4F82F9F00E7D4
Posted on Aug 30, 2010
Need msl code for galaxy s2 on sprint
1. Download "Terminal Emulator" from the app market.
2. Open Terminal Emulator.
3. type in getprop ril.MSL (make sure the .MSL is capitalized)
4. Press enter and poof, you have your MSL code.
Dec 08, 2013 | Samsung Galaxy Cell Phones
Nokia 6300 security code
What kind of phone is this? Android you can enter your password incorrect 5 times and you should be presented with a "Forgot Password?" button. Click that and enter the info about your primary account and it should allow you to change the password.
Dec 07, 2013 | Cell Phones
Password pattern is entered incorrectly three times
Contact your phone carrier. They will know how to help you.
Nov 30, 2013 | Cell Phones
How do i unlock a sanyo juno scp-2700 cell phone
my solution is real easy but in both case u gonna need msl code which u can get it from boost mobile just tell them u bought this phone online and and u need msl code to program it.press ##786# >RTN Menu>Reset>Enter MSL>Ok.
##3282#3G data programing scrol down to restore and put ur msl code and ur problem should be fixed.
Nov 25, 2011 | Sanyo Juno Scp 2700
How can i change my settings from NAM2 to NAM1 when my security code changed
This problem was solved for me using only the Calculator application onmy computer! The step-by-step instructions can be found at this link, or the Samsung support site.
Cheers!
Jan 09, 2010 | Samsung Smooth SCH-u350 Cell Phone
My phone says subsidy password and i dont kno the password
download metropcs spc msl calculator open it up put in your esn and pow spc = service program code = msl if you dont know your esn and only have meid download meid to esn converter
Dec 01, 2009 | Motorola Cell Phones
I can not unlock my phone. i forgot my password. I tried the last four digits, called Verizon, and they told me to call my manufacturer-(samsung). I tried, but since my phone was locked, i could only...
You need to get a USB cable for your phone. I got one for under $3 delivered shopping on the net. You need to download & install the 4.4 Samsung USB Drivers, Google, they are free. You need to download, install & run a program called QXDM to get your MSL/SPC code. Then you download & install Samsung PSTLite v10004. Run that with your phone plugged into the USB port & turned on. Double click on your phone, then click on the PREPAID PHONE button, lower left, then READ ALL, at which point enter your code (you can try 998076 & see if its the same as mine was. After it is done reading your phone, you clock on the info button & you will get your two unlock codes for your phone. One of those will be the one you need.
I got this from another users post, kirbykirbykirby3, it is not mine, though I have added a little bit more information:
Here's how I find out the MSL/SPC from the U350, works with almost any phone.
QXDM, Connect it via Serial Port. (Com Port USB set to port 1, & 2)
Go to command output:
Type in Password "password 1945081520081106"
Without the quotes
Press Enter Key
then type in "requestnvitemread sec_code"
Without the quotes
Press Enter Key
there you go, security code right there.
You can also change anything you want... hehe.
Now boot up Samsung PSTLite, double click your phone U350, then click on 'Prepay' in the lower left corner, then click on read phone, then input the security code you got with QXDM for the 'Input MSL Code'. You can then click on info, settings, transfer, etc., make a backup of your address book, even edit it. I have not figured out how to get at the pictures with this method though. If you figure that one out, please post here as I am subscribed to this thread. Thank you.
Nov 11, 2009 | Samsung Smooth SCH-u350 Cell Phone
I lost my unlock code what can i do?
Without the quotes
Press Enter Key
Without the quotes
Press Enter Key
Now boot up Samsung PSTLite, double click your phone U350, then click on 'Prepay' in the lower left corner, then click on read phone, then input the security code you got with QXDM for the 'Input MSL Code'. You can then click on info, settings, transfer, etc., make a backup of your address book, even edit it. I have not figured out how to get at the pictures with this method though. If you figure that one out, please post here as I am subscribed to this thread. Thank you. Samsung PSTLite will also give your your two lock codes. Your personal one & the phones code.
Oct 26, 2009 | Samsung Smooth SCH-u350 Cell Phone
I need to Progam a Samsung Smooth cell phone.
To Program any Samsung Verizon Phone:
+Go to Menu > Settings (may be listed as settings & tools depending on software version)
+Press the * Key (to the left of zero / 0)
+Enter the Service Programming Code (a.k.a. SPC, MSL, SEC) This code is usually 000000 for most Verizon phones, but if it was purchased prepaid you may have to get it from Verizon. Try 000000 first though.
+Go to Network Settings
You will now be in the programming menu. Enter the information as it pertains to the field indicated.
+When you have entered all of the programming information, press END.
The device will now reset and save the programming information.
Jul 25, 2009 | Cell Phones
Nextel ic502
If you have the 6 digit MSL code you press ##MSL# then the View Edit and Done screen will put up on its own. Then Select edit put your phone number in. Then press ok on the next screen it will ask for a MSID if you have this number enter it and then press ok, after entering the MSID the phone will go back to the Screen with the View Edit Done.....Select done and the phone I will reset.
Oct 27, 2007 | Sprint PM-8200 Cellular Phone
RIM BlackBerry 7250 Logo
1,363 people viewed this question
Top RIM Computers & Internet Experts
Andrew Wright
Trisha
Trisha
asber
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
