Question about GE (PSS26MSRSS) Side by Side Refrigerator
Temperature is 3/43 Ice forking in freezer - GE (PSS26MSRSS) Side by Side Refrigerator
    Sergeant:
    Champion:
  • 351 Answers
Hi more thin likely the deforst element. its in the back of the freezer jim
Posted on Oct 12, 2010
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
We cannot change the temperature of the freezer. Everything,even the water to the ice machine is so frozen (8*) that we cannot get ice. How do we change the temperature
I am not sure what model you have, but on my RF265AABP there are two buttons and digital displays at the top of the refrigerator, visible when the doors are open. One sets freezer temperature, the other refrigerator temperature. On my model if they read 88 88 with a blinking digit, it indicates a broken wire to a temperature sensor, usually the ice maker sensor since it tends to get snagged and damaged easily.
Apr 04, 2013 | Samsung 24.8 Cu. Ft. Side-by-Side...
Ice cream does not seem to freeze it is always very soft. Everything else freezes O.K.
hi icecream generaly depends on the mixture & consistency need more clarity....
All fresh ice cream is somewhat soft, but should not be liquid. It will never be hard like it is in store. Let it churn until it is the consistency of soft ice cream, and then let it harden a bit in the freezer to get to the consistency you want. It's possible you actually let it churn too long and it started melting again.
Another method I used is to just put the ingrediants in the bowl, put in the freezer, and then take it out of the freezer and churn it myself, moving a butter knife around the edges to get all the frozen parts out, then a fork to mash it up. The ice cream takes less time to freeze and is generally harder
Aug 08, 2011 | Refrigerators
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
GE ICE DISPENSER DOES NOT WORK
Remove the ice bin . Use a hairdryer , directly on the fork on the back of freezer . Try pressing the dispensor pad ocassionally , to see if forks unfrozen . When they do , reinstall the ice bin , and lower the freezer temp slightly .
Aug 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker makes ice but can't dispense ice
Please try this. Remove your Removable Ice Bucket Assembly which is where the Auger (corkscrew) is located. You should be able to see the Auger Motor Drive Fork which is located permanently inside the freezer compartment... opposite the end of the Removable Ice Bucket Assembly that you just took out. Close the freezer door and attempt to dispense ice... if you can hear the Auger Motor running as you attempt to dispense ice... then the Auger Motor is OK. Dump out all the ice that is in your Removable Ice Bucket Assembly and wash it out in your kitchen sink with warm water. Reach into your freezer and put your hand on the Auger Motor Drive Fork ... you should be able to rotate it CW or CCW...it is a little hard to turn but it will turn. Position the Auger Motor Fork to a 12:00 and 6:00 o'clock position. Now take your Removable Ice Bucket Assembly and position its Receiver Auger Fork to a 9:00 and 3:00 o'clock ....Re install the Removable Ice Bucket Assembly into the Auger Drive Fork. Close the freezer door and again attempt operate the ice dispenser... you should hear the Auger Motor again run as you press the ice dispenser. Note....at this same time the Ice Chute Door in the Freezer Door should spring open so that ice can fall out. Of course you have no ice in the Auger at this time...but it all this works then future production of ice will fall out. Note...Usually the Auger Motor never fails. but the whole thing can get jammed with ice and not dispense. Also, the the solenoid that operates the Ice Chute Door fails quite frequently. Last but not least... if nothing is happening... it is a control board type problem. Hopes this helps! Handy Henry
Jul 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Clicking noise, ice maker out, freezer temp high
Low temperatures are absolutely required for proper operation of ice makers components. Dirty cooling coils or possible low refrigerant.
Jul 08, 2009 | Freezers
Ice maker arm
you can take out the screws that hold the ice maker to the freezer wall unplug the ice maker take off the front cover remove the four screws holding the motor module which is brown take that off and reattach the shutoff bail arm and reassemble. their is a gold forked metal piece in there the bail arm has to be in that fork .or you can replace the ice maker
Jan 09, 2008 | Amana ARB9059CS Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
