Question about Whirlpool Dryers
Dryer would not turn off at end of time. Had to manually turn off. Now it will not come on at all.
    Scholar:
  • 110 Answers
Bad push to start switch or a thermal fuse blow due to overheating which probably means you have a venting issue which would have to be dealt with as well
Posted on Jun 01, 2008
I have a bosch gas dryer wtvc5530uc Is there a way to turn off the end of cycle signal? Thanks
Press the Dedicates and Eco action button at the same time. Here is an online resource for the manual, that is what is listed on page 20.
Bosch WTVC5530UC Manuals
Jan 24, 2017 | Bosch Dryers
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
I have a MDG5500AWW Maytag Dryer. Everything works fine but when it's sitting and off, no lights lit, it beeps 3 times every 10 minutes or so. Never timed it, could be less than 10 minutes. I usually...
Sounds like a prompt of some type...waiting for an input like to 'open the door' at end of cycle. Not sure myself but do believe the answere is in the customer service manual you received with the new machine. If you do not have one, go on line to get one.
Oct 17, 2013 | Maytag Neptune MDG5500AW Gas Dryer
How to shut off dryer end of cycle beep. Can u run
If the model number is correct, the dryer End of Cycle signal cannot be adjusted or turned off. The informatrion is listed on page 11 of the Owner's Manual:
http://www.managemylife.com/mmh/owner_manuals/16695/WHIRLPOOL-Laundry-Centers-L0710382?brand_name_search=LTE5243D
The only way to turn the signal off, is to remove the operator console, locate the signal (buzzer) module and disconnect the wire(s). The buzzer is listed as item 32 under the "Washer/Dryer Control Panel" parts listing:
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-YLTE5243DQ2/1198/0152000/W0702346/00001?blt=06&prst=&shdMod=
CAUTION: If you choose this option, make sure you UNPLUG the washer/dryer before servicing anything inside. If you disconnect any wires, make sure you cover them with heat shrink or electrical tape to keep them from coming into contact with anything else.
The washer and dryer use a common power source, but the rest of the functions operate independently of each other. You can safely run both units at the same time.
If need further assistance, please let me know. I hope this helps you.
Aug 09, 2011 | Whirlpool LTE5243D Top Load Stacked...
Dryer won't start. I bought it used and have no manual. I turn it to off at the end of the cycle. Then I set the new cycle and turn it on, it beeps but won't consistantly start. I'm thinking a bad switch?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | EuroTech EDV158 Electric Dryer
Have a retangle showing as the dryer ends it dry cycle. Dryer will dry but the rectangle shows up about 1 minute before dryer ends it's cycle.
I have the same problem with my dryer. I noticed this rectangle that showed up on time dry and there wasn't any code that matched this in the manual. I called samsung and they told me to flip the breaker and see if that helps. I have not tried another load, but I hope that fixed it.
Dec 03, 2009 | Samsung Dryers
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Samsung dryer DV328AER doesn't turn off
My Samsung dryer 8KG (SDC3K801) is not turning off after completed the cycle time. The panel showing end but the drum still running. If I choose Synthetics extra dry with auto cycle time 49, when the timer at 6, the display increased again to 25. It's seem the dryer is not stopping forever. Any suggestion please!. Thanks
Jul 20, 2009 | Samsung DV328AE Electric Dryer
Control locked on ghw920 can u help me unlock
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Open Questions:
Dryers Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
