Question about Friedrich QuietMaster KM18L30 Wall/Window Air Conditioner
Friedrich QuietMaster® KM18L30 does not have drain plug and now its spewing water through vents and leaking. What should I do to correct problem
3 Suggested Answers
roniecon
  • 6927 Answers
SOURCE: Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Posted on Jul 04, 2009
heatman101
  • 43501 Answers
SOURCE: Friedrich QuietMaster SS08J10R Air Conditioner is not working
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
How do i recharge freon for me Friedrich KM18J30A-3 window unit?
only a certified HVAC technician has the license to carry and use the freon used in home A/C units. it's not like the car units we can do ourselves.
Jul 14, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
Compressor wont start
Check power to compressor relay and start capacitor before condemning compressor. Also check it's not low on gas.
Apr 18, 2012 | Friedrich QuietMaster KM18L30 Wall/Window...
My quiet master is leaking water inside my store.How can I drain the water.
1. check the filter.2. remove the front cover and check the front coil behind the filter and check any drains that might be plugged. some units do not have drains and if not that is fine. 3 Be certian that the unit is tilted to the outside about 1 inch or so.. It should then drain as it is designed.. hope this helps let me know.. Jon
Aug 03, 2011 | Friedrich QuietMaster SL35J30 Air...
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Need replacement cover or grille for model # KM18J30
Johnson supply out of Texas has an account with Freidrich. They are an A/C supply house. I believe they are based out of Houston. I would give them a call and see if you can get one through them.
Mar 19, 2009 | Friedrich QuietMaster KM18L30 Wall/Window...
Water Leaking into room
if you can see a drain blow backwards through it.It may also just be angled the wrong direction(the whole unit).If you cant see an external drain,unplug the unit and take the cover off .you should then be able to clear it.
Jul 07, 2008 | Friedrich QuietMaster Electric SS10J10AR...
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Friedrich QuietMaster KM18L30 Wall/Window Air Conditioner Logo
111 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
