Question about Maytag Neptune MDG5500AW Gas Dryer
My Maytag Performa Model number: PYG2300AWW runs through cycle perfectly but does not heat up; does not ignite.
SASSYBEAR
  • 148 Answers
SOURCE: maytag performa model#pyg2300aww takes four cycles to dry
how long is dryer vent run ? does it go up or out to the side ? Sounds like the dryer vent is clogged. A long run on your vent will also cause this problem with a small amount of lint. Try cleaning out your lint screen on the dryer vent they can get pretty caked up with lint. If you have a long dryer vent run post back the length and direction and I will get you the maximum length for your specific run. You may need a booster fan if it is excessively long or straight up as through the roof.
Posted on Dec 31, 2008
  • 77 Answers
SOURCE: Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
Posted on May 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: How to replace heating element Maytag Performa
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Posted on Jun 22, 2009
Illeagle
  • 525 Answers
SOURCE: maytag performa dryer will not heat up
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
maytag performa dryer Model PDGT910AWW
"No Heat" complaint.
Firstly, make sure that you have selected/ascertained a "Heat" setting, then read the checklist below provided by; www.repairclinic.com
They also provide disassembly diagrams and repair parts..
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
  • 1218 Answers
SOURCE: maytag gas dryer would run half cycle until it
Good day,
Every indication the motor is failing. Not uncommon.
Could be a bearing dragging badly, or idler assembly bearings, doing the same thing, but
A complete tear down of the dryer would need to be done to verify the problem.
Once again,figure the motor as the problem.
Thank you for using FixYa
Posted on Dec 25, 2009
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
My dryer is no longer putting out hot air only cold. Is their a quick fix to this problem. It is a maytag performa model pyg2300aww
Your dryer most likely has a bad: 1. Hi Limit thermostat 2. Heater Element 3. Thermostat. You will need a meter to check these. No quick fix. Sorry.
Jul 28, 2010 | Dryers
My Maytag Performa PYG2300AWW dryer quit working today. 1st we noticed it wasn't dying clothes, then there was a smell. We thought the lint was clogging it up, so we vacuumed everything out. Now it won't...
This could be the thermal fuse or Hi Limit thermostat possibly a few other components. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting procedure. It's a different model but testing and components are the same.
Mar 27, 2010 | Maytag Performa PAV2200
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Jun 22, 2009 | Maytag Dryers
May 12, 2009 | Maytag Dryers
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Dec 29, 2008 | Dryers
Maytag performa model#pyg2300aww takes four cycles to dry
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
No heat from dryer.
Do not buy or use a maytag performa dryer model number pye2300ay at all. I fyou have one unplug it and take to the landfill or scrap yard. They are complete junk and nothing but a hassle. One problem after the other on this model no matter what you do. they are complete trash and a waste of your money.
Nov 24, 2008 | Maytag Performa PAV2200
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Maytag Neptune MDG5500AW Gas Dryer Logo
100 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
