Question about Gateway ML6732 Notebook
I have a Gateway ML6732..one of the keys popped off...can I repair this myself or do I need to take it to a repair shop? Thanks Burt
  • Gateway Master
  • 15,579 Answers
Just press it back on until it clicks. All keys are removeable.
Posted on Oct 11, 2010
Gateway laptop ml6732 has a startup repair screen and won't boot
Please re install OS .
Please specify what exactly went wrong when u used setup cd to re install
Jan 05, 2013 | Gateway ML6732 Notebook
My Gateway ML6732 says the operating system isn't found. What can I do to reinstall the OS?
buy a copy of Windows OS or you can download Linux that is free like ( Ubuntu, Fedora, Debian, LinuxMint). insert the disk on the computer and just follow instructions. you should have a working os i no time.
Mar 08, 2011 | Gateway ML6732 Notebook
It is normal for a Gateway ML6732 that the fan starts when turn on the laptop and then stops the fan couple seconds after that? My laptop gets freeze all the time seconds after.
That is normal for when the laptop starts up. That is also a good indication that the fan is working ok. If the fan loud and noisy all the time then there is a build up of dust in the machine and it needs cleaning out,
Regards.
Jan 23, 2011 | Gateway ML6732 Notebook
Gateway ML6732 Sound Malfuction
sOUNDS LIKE YOU HAVE DONE SOME SERIOUS DAMAGE TO YOUR LAPTOP
Jan 02, 2010 | HP Pavilion dv9000z Notebook
Keyboard on ml6232- some of the keys on the right side are messed up. example press p and get 7, press o and get 6, press i and get 5 please help
You have to thurn this feature off ... look for a key marked "fN" on the lower left side. this switch toggles (turns on and off , alternatively) the key pad imbeded into your keyboard
Thanks for your interest in FixYa.com
Dec 11, 2009 | Gateway ML6732 Notebook
I can't get my mouse to work properly on my ML6732. The right button and center pad isn't working properly...
if its on warrenty : take it back to shop not on warrenty: Take it back to shop If u wanne Experiment and try urself: Look under the pad.
Jun 05, 2009 | Gateway ML6732 Notebook
Gateway ml6732 laptop keyboard
Some keyboards have connectors but most have electrical strip.
These slide into a connector on the motherboard, you can't miss it, it is the same width as the electrical strip, but you need to lift a plastic strip retainer to insert the electrical strip and then press the plastic strip back to lock the electrical strip in place.
Apr 26, 2009 | Gateway ML6732 Notebook
Need replacement keyboard for gateway ml6732 laptop computer, don't have the old one and have no idea how to put it in. Need directs and need to know if screws come with new keyboard, or if it takes screws...
You may be able to get from Gateway. From a quick search I just did, it looks like Mundo Corp.com, has one. $49 dollars Here is the link,
http://www.mundocorp.com/ml6732.html
Now I don't have a Gateway Service Manual in front of me, for the Gateway ML6732 laptop. I don't believe it's available online. One, has to be an authorized repair shop, to have access to this information.
However, I wish you to know that I am a computer repair tech, and repair laptops all the time.
Keyboard replacement is one of the easier things to do, concerning repairing a laptop.
It is especially easy now for you, as you don't have to remove the old one.
The laptop keyboard will just come by itself, I believe. There are one, or two screws, that hold it in. However, the keyboard has tangs on the outside edges of it. The keyboard 'body' is made of plastic.
These tangs, are just small protrusions, that stick out from the rectangular body of the keyboard itself. The tangs also hold the keyboard in place. Once you sit the keyboard in place, you just push down on the edges, and the tangs snap in. Pop, pop, pop, and the tangs are snapped in.
Before you are ready to install the keyboard, you may have to partially remove a small thin plastic strip. This strip is located above where the keyboard goes, and under the area of the LCD screen.
Viewing it, you should see LED lights in it. There may be speakers in this strip also. The plastic strip goes almost all the way across the front of the laptop.
I know it's starting to sound complicated, but it isn't.
This plastic strip may also have hinge covers, incorporated on the ends of it. They cover the hinges for the LCD screen.
The plastic strip has tangs on it's edges also. To remove it, you take a small flat tip screwdriver,(Like a flat tip jewelers screwdriver), insert it under one of the edges, where it meets the laptop body, and gently pry up.
I say 'Gently', but sometimes it takes a little force. If you can't get the screwdriver down in there, move over. You may be at an area where on of the tangs are.
The strip will come up with a POP! You'll think you broke it! In actuality, you could drive a truck over that plastic strip, and not damage it. (Okay! That's an exaggeration, but you catch my drift)
Watch as you go along. If you have LED lamps in this strip, and/or speaker wires, you don't want to damage the wires.
You are just seeing if you can pop it up, so that you can set it towards the LCD screen. Move it back far enough to get the keyboard in. Should you have to disconnect the wires to move this strip back far enough, you will see real small White connectors. Looks like a small rectangular block. This is a Male/Female connector. Just take your fingernails, and pry these apart.
There may be two wire cables. These cables have different size connectors, so there will be no confusion when reattaching them together.
The laptop keyboard goes in at a 45 degree angle. Bottom towards you, top away from you. You set it down in the laptop body, align the tabs, (tangs), and ease it down. Once you are within about three inches, you connect the one, or two wire cable connectors, from the laptop to the keyboard. Move the cables to a position where they won't be pinched, and go ahead and push the keyboard down into position. Go along the edges of the keyboard, and push down. You are snapping the tangs into position. Snap, snap, snap.
Attach the cables for the plastic strip, if you had to remove them. Watch the cable, (Wire) placement as you did for the keyboard. Snap the plastic strip back into place.
You're done!
This link shows the Gateway MT6704 laptop. It should be very similar to yours. It has large color photos, and instructions, of how to replace a keyboard on this laptop. It should give a basic 'feel' of how to replace yours,
http://www.insidemylaptop.com/remove-keyboard-from-gateway-mt6704-model-ma7/
(If this link doesn't come up as a link you just click on, copy (CTRL + C), and Paste, (CTRL +V), it into your address bar. Then press the Enter key)
If you get time, I would appreciate it if you would rate my solution.
Apr 16, 2009 | Gateway ML6732 Notebook
Gateway ML6732 Crashed ...NEED help
Seems you have OS (first guess) problem so if you have recovery disk then insert it in DVD/CD driver and reboot your laptop.
And follow the instructions appeared on sreen and when you reach installation mode choose repair one if you wanna repair OS otherwise choose fresh Installation.
once you are done you should be good to go and if you have Hardware problems then your system will show the bugs on screen during installation period.
oh! if you have any external drives (Thumb drive, Ipod) plugged in then remove before you start above procedure because due to external drives also it happens if you dont have any plugged in external drives then follow the above procedure.
Thank you and post back if any thing changes.
Jan 02, 2009 | Gateway ML6732 Notebook
Gateway ML6732 Notebook Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
