Question about Gateway 310X PC Desktop
Display my display resolution is stuck at 4 bit and it's not allowing me to change. No other options are eevn displayed, only 4 bit and the resolution metr is stuck down at low quality not letting me move it.
    Problem Solver:
  • 31 Answers
Try going into safe mode and remove the video driver.
To go to safe mode you will need to press the F8 key.
Step one = turn the pwr on and press the F8 about 8 times
Step 2 = select safe mode
Posted on Jun 01, 2008
Hi. The colour on my HP/Compaq 6820s laptop is a bit dull in comparison to my second extended Samsung monitor. I want to adjust the colour settings on the laptop, but all I can find on the keyboard is...
If you right hand mouse click on your desktop picture, a menu will become available. Click on Screen resolution and then Advanced settings. There will be options inside that window to allow you adjustment of the display.
Hope that helps.
Nov 25, 2010 | HP Smart Buy - HP Compaq 6820s Notebook PC...
I've just bought a new tower, hitched it up to the monitor - when I turn it on, it comes up, Windows begins, and then the monitor says the input signal is wrong, asks to have the resolution chnaged (I've...
The best way to solve this problem is to Boot windows with a reduced resolution of 800x600.
To do this, If you turn the PC off without properly shutting it down the option should be available if you press F8 when windows states "Your computer was not shut down properly"
Otherwise keep tapping F8 from the time you press the power on button and the boot options should appear.
Then select the option "Boot windows with reduced resolution quality "800x600"
Once windows boots up go to the Display properties by right clicking on the desktop and selecting display.
You should be presented with a window which customizes your desktop and allows you to change display resolutions. Open the window which allows you to change resolution and select the advanced option. Then you should be presented with another window which is the display driver properties. In this window select the monitor tab and make sure the box which say's "hide modes which this monitor can not display" is Ticked and this should solve your problem no matter which resolution you chose.
Apr 10, 2010 | HP vs19 19" LCD Monitor
My moneter sceen picture has become large and out of focus
i  think there was  a problem with system monitor resolution setting,please follow the given steps and check the monitor setting-
1-Right click and go to property option
2-chose setting option
3-check screen resolution,standard size is 1024 by 786 pixels and color quality is highest 32 bits
  and also check advanced option under setting DPI setting is normal size 96 DPI ,choose all option than apply and ok.
Thats helpful to you.
Thanks,
Dec 13, 2009 | Computers & Internet
The desktop on my monitor is square and no-longer fits the screen, how do I turn it back to an desktop image that entirely covers the screen?
This will depend on what operating system you are using:
Win 98/ME/2000/XP/XP PRO/XP 64-bit
1. Click on the start button
2. Click on Control Panel
3. When Control Panel opens, find the Display icon and double click
4. When the display properties window opens, click on the tab towards the top labeled settings.
5. Move the slider under the option Resolution all the way to the right or desired resolution if you know it.
6. Click apply and make changes (try another resolution) if necessary.
7. Once you have found the appropriate resolution, click OK.
Win Vista
3. Double click Personalize
3. Scroll to the bottome and click Display Settings
4. Move the resolution slider to appropriate resolution
5. Click apply and make changes as necessary
6. Click Ok when done
Hope this helps!
PS - Please rate the help provided. Your time is much appreciated!
Oct 15, 2009 | Acer Computers & Internet
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Gateway 310X PC Desktop Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
