Question about Refrigerators
Sylvania 4.5cu. ft. Compact refrigerator Model # SE80105-1/SE80105-3 intermittently and spontaneously begins to defrost leaking water into the storage compartment when the control knob is not on 'O' or Off position and the unit is plugged in. Frustrating, messy and annoying. gej
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
  • 749 Answers
SOURCE: Whirlpool Refrigerator Model No. WRN28RWG6
if the flap was open then truely excessive cold air is coming out/escape from the freezer causing no freezeing. you need to defrost your fridge.
Note also that frost build up increases time to freeze your food on the freezer. it also causes your fridge an increase in electricity consumption.
defrost your fridge for some time ti remove the frost build-up.
Posted on Nov 19, 2007
aborcass
  • 2651 Answers
SOURCE: defroster leaks
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Feb 25, 2008
peyton32034
  • 410 Answers
SOURCE: Model 78182891 Coldspot with excessive water Collecting in Refrig
Most likely whats happening is you have a frozen drain for the defrost cycle. here are step by step instrutions for repair:
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Post bak if you have any questions and I'll gladly help you out Thanks Peyton
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Water from automatic defrost leaks into refrigerator.
drain clogged
Posted on Apr 01, 2009
Black and decker refrigerator model BCFA27B not working
Check any defrost water hasn't got into the electrics and blown a fuse.
May 28, 2014 | Black and Decker USA Black & Decker 2.7 cu...
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water leaks on the floor occassionly may happen during defrost GE Model TDC18PAAWW
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Jun 03, 2010 | GE Profile Stainless Bottom-Freezer...
Uhhhhhh
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Dec 22, 2009 | Maytag MBF1956HEQ / MBF1956HEW /...
Water is leeking below the refrigerator. I cannot see where the leeking is coming from. Any ideas where to look?
Dec 22, 2009 | Amana ATB1832AR Top Freezer Refrigerator
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore top freezer leaking water on the inside when defrosting
MAKE SURE THE FAN IN REAR OF FREEZER COMPARTMENT IS RUNNING , SOME TIME YOU MUST DEPRESS THE DOOR SWITCH ON THE FREEZER DOOR TO WATCH FAN IF NOT REPLACE FAN , NOT BAD MOST UNPLUG , IF THIS IS NOT IT YOU COULD HAVE A INTERMITTENT DEFROST TIMER OR A BAD DEFROST HEATER
Feb 24, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Water leaks out of the bottom hindge part of our freezer door. It is intermittent and not a lot maby 1/4 cup.
This sounds like a problem with the defrost drain being plugged. Find that drain pan...look for the drain and clean it.
Refrigerators Logo
302 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
