Question about Yamaha HTR6230 Receiver
There is no sound when yamaha HTR-6230 is HDMI cable is connected to PS3
SOURCE: Yamaha HTR-6230 receiver set up w/HDMI no sound
I also had this problem. you need to call Yamaha Tech Support (in your country) and explain to the consultant that you need to set up your receiver to decode the Audio from the HDMI input (so it will play the sound from the HDMI cable). Yamaha Australia said that this function is not described in the book and also said its a stupid mistake on Yamaha's Manual. So just give them a call and they will fix it for you. It WORKED for me :D
Posted on May 09, 2011
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 40 Answers
SOURCE: problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Posted on Jul 25, 2009
SOURCE: Ok- I need step by step, easy to understand
Hi brily, yes you need to conned another optical cables with your HDMI cables since in this model the HDMI is "switching" and the HDMI doesn't cary the sound ... I just bout home theater with this recievr model and I had to buy the extra optical cables to get the sound .
hope this answer your question .
Posted on Jan 06, 2010
Nomodo4u
  • 863 Answers
SOURCE: how do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
Posted on Feb 18, 2010
Yamaha HTR-5830 does not work with Sony PS3 optical cable connection. There is no sound at all. Do I need an HDMI cable. Right now I only have component cables which work fine with the red and white...
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
Jun 04, 2010 | Yamaha HTR-5830 Receiver
Trying to get the sound to work with my HD DVR and PS3 using HDMI cables
Your receiver probably doesn't support audio over HDMI - according to specs, it has just hdmi switching, but not hdmi repeating.
You have to connect PS3 via optical spdif cable to the receiver.
Mar 06, 2010 | Yamaha HTR-6130 Receiver
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
How do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Feb 18, 2010 | Yamaha RX-V463 Receiver
Ok- I need step by step, easy to understand directions. I just bought a Yamaha HTR-6230. I need to be able to connect this receiver to my plasma samsung, PS3 and cox HD cable box. what cables do i need and...
Dec 30, 2009 | Yamaha RX-V463 Receiver
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR6230 Receiver Logo
190 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
