Question about eMachines T6524 PC Desktop
Have an e machine t6524 that was rebooting itself now it won't boot up at all. Keeps beeping
  • eMachines Master
  • 11,800 Answers
Hardware fault. Simple test: if you can boot in the BIOS then the hard disk has died - replace it and reinstall. If you can't the the motherboard has failed - in the end it will be easier and cheaper just to get a new pc.
Posted on Oct 11, 2010
Compaq presario beeps 3 times, won't boot
3 Beeps is usually a RAM issue. Try re-seating your RAM in their slots and rebooting.
Feb 05, 2012 | HP Compaq Presario SR5262NX Desktop PC
Emachines T6524 will not reboot, get no signal message on monitor
shut down your computer and remove the side cover and remove the memory from the slot and switch on the computer if you hear beeps switch down the computer and insert the memory if you still hear beeps means the tre is an memory failure you need to change the memory while removing memory you didnt hear any beep it means there is problem with your motherboard remove the processor heat sink and the processor clean the surface then insert the processor to the slot apply a thin level of heatsink compound and fix the heat sink then switch on the computer
Dec 29, 2011 | E-Machines eMachines Desktop PC
ERecovery Management
Mite try taking the disc out when rebooting
Apr 14, 2017 | Gateway ZX4351-47 21.5-Inch All-in-One...
7/1/11 eMachine T6211 won't boot at all; no fan starting, monitor says there is no connection and there is beeping that does not stop. Short beeps spaced evenly. Could it be bad capacitors? When...
Most probably is a RAM memory issue, those beeps are issued when a RAM module can not be found, may be the machine sufferend a crash an the ram jumped out of it's slot (less probable) or just broke (Most probably) certainly a tecnician can save your data to another PC or even, fix the broken PC by replacing the broken RAM module with a new one
Jul 02, 2011 | eMachines T6211 PC Desktop
Alarm beeps on startup and will only let me put in 1st digit of password beforekeyboard wont work anymore
Beeping on startup is an indication of a RAM memory problem. If you have more than 1 stick of RAM installed, try removing 1 and rebooting. If it boots up, you may have a motherboard issue that won't allow your machine to utilize all of your RAM memory.
May 14, 2011 | Acer Aspire One PC Notebook
Want to restore os and start over. Emachine t6524
Have you tried System Restore? Restart your computer and watch for the screen to give you instructions at the bottom. It will say something like: F1 = Boot Menu F10=System Restore
It should walk you through a factory restore, which means it will take it back to factory settings the same as when it was perchased.
Feb 04, 2011 | E-Machines T6524 PC Desktop
BSOD after power failure during check disk-now I cannot reboot from recovery console or disk. How can I uninstall the OS then reinstall OS from eMachines T6524?
You need to enter the BIOS. immediately upon starting the computer start tapping either the F2 or the tab button. Once in the bios, go to boot order and set the cd/dvd drive as the first boot priority, hard drive second. It is ok to leave this permanently, save and close settings which will reboot the system and considering everything goes as planned you should be able to start up from a disk and then repair or replace XP. When replacing XP remember to delete partition and write a new copy. THIS WILL ERASE ALL INFO ALREADY ON THE HARD DRIVE!!!
Feb 23, 2010 | E-Machines T6524 PC Desktop
MY T6524, will not start I press the button and the hard drive light goes red then nothing comes on the monitor
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Nov 19, 2009 | E-Machines T6524 PC Desktop
T6524 bios update needed
This isnt necessarily a bios problem mate , its just windows got corrupted during the power surge. Use the link below to do a repair install. Note , repair installs do not erase your personal files or setings or software !
http://michaelstevenstech.com/XPrepairinstall.htm#RI
Hope this helps you
If you found this solution helpful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | E-Machines T6524 PC Desktop
I ahve an emachine T6524 and when you start it up the hard drive light comes on yellow and the cpu keeps beeping. It never seems to boot up. Nothing appears on the screen
hello...the exact problem on the CPU/unit is Memory so you need to try clean the memory or try to replace a new memory...Thanks and Good Luck...
May 09, 2009 | E-Machines T6524 PC Desktop
eMachines T6524  PC Desktop Logo
115 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
