Question about Gateway M305CRV Notebook
I have a Gateway tablet (notebook) TA7 laptop and the computer will turn on but the screen is completely black with no appearances of images at all,
spiffyrodent
  • 85 Answers
SOURCE: when I turn on my computer, the screen stays black
hook up an external monitor to it (old crt monitors are good for something after all) and try pressing the function key and holding it down while pressing each of the F1 through F12 keys (we are trying to switch the display to an external monitor) the one you are looking for has a (O) looking symbol above it.
if that does not work look for a stuck screen closed button switch. that detects when the screen is closed and shuts off the monitor see if its stuck down and try and free it if it is stuck.
you may also try to hold a bright flashlight up to the screen at an angle if you can just make out some details then the screens back light is out. and will need to be replaced.
Posted on Sep 10, 2009
myob247
  • 1342 Answers
SOURCE: i turn on my gateway notebook, get 3 beeps & a blank screen "HELP ME smart people"
You probably knocked something loose when you dropped it. Try re-seating your memory cards. 3 beeps is usually a memory issue.
Posted on Jun 27, 2008
  • 5 Answers
SOURCE: Gateway PC Notebook/Tablet Model: CX2618 Monitor Replacement
First shine a flashlight on the screen. if you can see a very faint image on the screen the problem is the backlight. If not... it could be a few other problems, first test if it works on an external monitor. If it can then you need to cleear the CMOS. to do this you unplug the cord remove the battery and hold down the ON button for 30-60 seconds, then turn it on. If it does not work on the external monitor it is probally because you have a bad video card and need to replace it.
Posted on May 26, 2009
  • 5 Answers
SOURCE: My gateway laptop gives me a black screen when I
Attach a external monitor and reboot -- if it comes up then the LCD on the laptop may be broken / damaged. Usually this is an issue with the back light from my experience. This is where I would start -- there are many other more complex issues it may be as well but this is the simplest. If the laptop was recently purchased I would look into what is covered by your warranty.
Posted on Oct 01, 2009
budmrtn
  • 11361 Answers
SOURCE: power comes on but screen stays black
The backlight inverter board may be bad, or worst case will be bad lamp. You should look to see if the cable comes off the inverter board first. You may learn maore here:
http://www.insidemylaptop.com/category/5-gateway-laptops/
Please post back what you find.
Posted on Nov 15, 2009
Laptop screen is just black gateway TA7
Try plugging into an external device live a tv or monitor see if you get a picture
Oct 10, 2014 | Computers & Internet
Why is my Gateway 4028GZ screen black
The display on this laptop is backlit. What that means, in a nutshell, is that the image on the display prevents the output from a constant light source (the back light) from showing through, thus giving a usable image on the screen. From your description, the backlight is no longer operating. This can be an issue with the LCD display panel, the backlight power module, our (less likely) a power trace on the motherboard. Repair would likely cost as much or more than replacing with a used laptop and just transferring your hard drive. If you choose to replace and swap hard drives make certain that the interface on the new laptop is the same as your Gateway's.
Jun 08, 2017 | Gateway 4028GZ Notebook
Power comes on but screen stays black
Nov 15, 2009 | Gateway M465-E Notebook
When I turn on my computer, the screen stays black
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Gateway MX6956 Notebook
Screen isnt booting up, laptop opens all the way- broken?
The computer will not work without a hard drive.
Most laptops screens will go all the way back.
Enjoy.
Jul 08, 2009 | Gateway MT3422 RTL Notebook
Jan 28, 2009 | Gateway CX2618 Notebook
Black screen
When i connect an external monitor and use Fn+F3 i was able to see the computer so i guess either the backlight or the inverter is not functional
Sep 22, 2008 | Gateway M305CRV Notebook
Gateway laptop mx6448
Try booting from dvd drive with rescue disk
Jul 10, 2008 | Compaq Presario M2000 Notebook
Gateway Laptop
This is either an operating system failure or hard drive failure. Start by reloading a fresh operating system (Vista) with your recovery or operating system disc. If you have any problems during or after the install, then it's the hard drive and will need to be replaced.
Jun 25, 2008 | Gateway MX6920 Notebook
Gateway M305CRV Notebook Logo
752 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
