Question about Sub-Zero 690 Side by Side Refrigerator
Thermostat is reading 54 degrees. Where is the condenser so perhaps I can clean it.
  • 1,891 Answers
The compressor should be behind the panel on top . this is where the condenser is and the fan that cools it . remove the front and with a coil bursh ( this is a long like a ant eater looking brush. ) brush the coils and vacume the . clean the fan blades with te brush also .. mm
Posted on Oct 11, 2010
SOURCE:
My refrigerator has a temperature of 54 degrees already cleaned the compressor. What do I do next?
Did you clean the compressor, the round kettle-like thing, or the condenser, the thing that looks like a radiator?
If you did, then you need a service engineer to check if it needs gas.
Jun 16, 2018 | Refrigerators
ULINE wine cooler 3018WCSA... Freezing occurs at the bottom of the unit.
Yes, the thermostat is full open. It needs replacing.
Apr 12, 2018 | Refrigerators
My freezer won't freeze any lower than 05 degrees no matter what you set it on ... why won't it freeze any lower
Door gasket ok? Accurate thermostat reading? Clean condenser coil? Incorrect freon level in unit.
Aug 21, 2017 | Refrigerators
Why does temperature fluctuate between 30 and 65 degrees all day long?
Check and clean the condenser, set thermostat to 3 or 4. If still problem persists, change thermostat.
Dec 08, 2015 | True Refrigeration Black True GDM-33SSL-54...
Freezer Temp Rises to 54
sounds like defrost heater is stuck on
Jan 04, 2014 | Sub-Zero 680 / F
Our refrigerator is freezing items in the refrigerator with the temperature set at 40 degrees. Do you know why?
You need to test the thermistors in the unit. It should read around 10,000 ohms at room temperature and around 29,500 ohms at 36 degrees. If it is not reading properly, you will need to replace the thermistor kit. Here is the kit to order.
The thermistor is located in the light assembly.
Nov 18, 2012 | Amana ABB1927DE Bottom Freezer...
Unit is about 10 years old, bought new from Lowes. When I open the doors the bar or middle frame is warm to hot. Now the freezer and refrigerator is not cold. Ice started to melt down so I removed the ice...
I suspect the warm to hot is from a heater that keeps moisture from from condensing on that bar. you don't notice it when the unit is working properly. Make sure your condenser fan is running and that condenser is clean. You may have a compressor that is failing
Jun 23, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My thermostat shows wrong numbers! Not possible temps but 5 to 20
Hi, your thermostat is reading celius instead of F.Degrees. There should be a switch under the cover or in the program for you to change back.
Shastalaker7
Dec 30, 2009 | Heating & Cooling
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
Sub-Zero 690 Side by Side Refrigerator Logo
392 people viewed this question
Top Sub-Zero Refrigerators Experts
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
john h
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
