Question about Kenmore Microwave Ovens
The microwave not heating the food ck fuse ok
  • 1,606 Answers
If the microwave is not heating and isn't caused by it being in a strange mode then this usually means that either the magnatron or the power transistors have failed. Either of these are repairable but the repairs are not that cheap. So the repairs can cost more than a new microwave. The power transistors are worth about $5 and then you might get charged say $75 for labour. So the question then is if it is cheaper to fix it or replace it with a new one. If you have a higher end one that is worth more then it can be worth fixing. If it is a lower cost unit then just replace it. Get an repair estimate first and know what a suitable replacement costs and use that as your guide for what to do.
You can find appliance repair shops either from stores or contact Kenmore(Sears) to see if they have a repair depot near you.
Posted on Oct 11, 2010
Want run or turn on to heat food
if your microwave is not heating food there could be two possible reasons. firstly maybe its the high voltage fuse that's gone,in that case the display is on the motor rotates but no heating since power is not reaching the magnetron. Secondly if your high voltage fuse is ok,display is there but no heating, the magnetron is faulty and it needs replacement
Nov 21, 2012 | Microwave Ovens
Heating problem
see this causes and fix it. God bless you
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Sep 27, 2012 | Microwave Ovens
Our GE JVM 1653 spacemaker microwave looks like it is working but the food doesn't heat up. It lights up and goes around but no heat? Whats up?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ysss
Jul 06, 2010 | GE JVM1653 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Microwave not heating food
There is a fuse or fusable link inline to the brain of the microwave.
This fuse is inside the actual microwave cover. Remove the cover and follow the electical line from the plug forward and you should see the fuse. Replacement fuses can be bought at an appliance parts house.
Dave
Jan 21, 2010 | Microwave Ovens
EVERYTHING ELSE IS WORKING BE WILL NOT HEAT FOOD KENMORE MICROWAVE
Mostly the problem may be with the defective magnetron., before replacing the magnetron you can check the fuse and the voltage at the primary winding of the Highvoltage transformer. If they are ok replace the magnetron.
Jul 08, 2009 | Maytag MMC5000 Microwave Oven
Everything works on the microwave but wont heat food.
You need to remove the cover, (Power Unplugged!!) look for and check a long glass fuse (usually in a plastic housing)
It's 5000 volt and less then one amp rating.
It's a small wire inside fuse so check it with a meter.
If it's ok, it's most likely the Magnetron which is usually half the price of the machine.
If the fuse has blown, see if there is a black diode, 30-40 mm long, one end is screwed to the case.
Disconnect one end, If you have continuity both directions, it's failed causing the fuse to blow.
Replace that diode / high voltage rectifier and then the fuse.
You should be back in business.
jb
Mar 16, 2009 | Maytag MMV5156AAS Microwave Oven
Microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Feb 03, 2009 | Whirlpool GH8155XM Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Microwave Ovens Logo
247 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
