Question about Fuji FinePix F20 Digital Camera
Cannot see camera when connected via usb
This is my third Fuji digital camera, and the first one that does not show up on my explorer menu when the camera is connected to my computer. I am beyond frustrated! The iteration of FinePix viewer that came with this camera is also problematic. I can live with the software if I could SEE the camera and remove my images from it using Windows Explorer. Help!
Nori
  • Nori Lamphere Jul 08, 2008
    I solved the problem by removing all the Fuji software and using a purchased card reader. Problem solved.
    I uninstalled the Fuji software and am using a card reader to manage my camera images. The Fuji software is a nightmare, and this solution is simple, inexpensive and fast. It also doesn't deplete my camera's battery.
    President:
  • 423 Answers
Try uninstalling any Fuji related software that is currently on your computer, then see if Windows can locate the camera when it is plugged in to your USB port. XP should locate the hardware, but a conflict with the software may prevent it from doing so.
Posted on Jul 08, 2008
Fuji finepix a 345 is not showing dsc photo folder when connected to pc. PC can't read file header. Memory card shows full (less 8 mb). cannot access photos. Kindly guide what is to be done. Thx.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 24, 2012 | Fuji FinePix A345 Digital Camera
Tip
Fuji Finepix a360
If having trouble downloading the photos to via USB (from the camera to a PC)
1) Camera to be on viewing mode
2) Clock the Menu/ok button to display the menu
3) Find the blue screen titled OPTION
4) Select the "Set-up" by clicking the Menu/Ok button
5) Select option #4
6) Select "USB MODE" and click the "Menu/Ok" button
7) Choose the icon that looks like a square with a curved bottom
8) Click the "Menu/Ok" button
...you are set!
cadman4u@yahoo.com
on Sep 23, 2008 | Fuji FinePix A360 Digital Camera
Can i charge my camera with the usb
No, charging the battery via USB port is not possible with your Fuji Finepix Z20fd Digital Camera. The USB port can be used for just 2 purposes: (1) connect to USB-compatible printer (to directly print pix), and (2) connect to a PC with a USB port (to upload pix). The only way to charge the camera's batttery
looks like the separate "supplied battery charger."
Check out page iv. of the onine version of your camera"s Users Manual.
http://http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/z/finepix_z20fd_manual_01.pdf
Jun 09, 2011 | Fuji Finepix Z20fd Digital Camera
I do not know how to set the time stamp for my FUJIFILM S1500. The date appears on the display screen when I view the pictures I have taken, but no longer appears once I download them to my computer??
The Fuji FinePix S1000FD camera supports time stamping only when printing pictures via USB with a printer that supports PictBridge. Otherwise, you will need to download the images and use an application such as "Visua Photo Time Stamp."
To print with PictBridge,
  1. Connect the camera to the printer and make sure the printer is on.
  2. Press the right-pointing arrow and hold for a second or until the USB logo is displayed on the camera
  3. Press the DISP/BACK button on the camera
  4. On the menu, select the PRINT WITH DATE option and press MENU/OK.
  5. Press MENU/OK again to start printing.
May 04, 2011 | Fuji FinePix S1000FD Digital Camera
I have a fuji 3800 digital camera with usb connector and I want to upload the photos onto my PC. The cammera does not show up in my computer, how do I do it?
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 23, 2011 | Fuji FinePix 3800 Digital Camera
Plz tell me set a english language
Connect your camera to pc via usb go to menu and just reset the language there if not try doing it straight ffrom the cameras menu please give thumbs up if this helps thanks
Feb 13, 2011 | Fuji Cameras
Transferring to PC
Having gone over a month with no response, I assume this is no longer a problem.
Jul 04, 2010 | Fuji FinePix A403 Digital Camera
How do I download pictures from fuji finepix s1000? I am sure that software is already on computer I just can't locate it or the protocol
Check if your programm list contains FinePixViewer, the software comes with the camera. If it is there then all you have to do is to connect the camera to computer by the USB cord provided along with camera. Switch on the camera The computer screen will show a pop menu showing various options Choose the download options once the images are downloaded save them in the appropriate folder
Nov 22, 2009 | Fuji FinePix S1000FD Digital Camera
Compact flash card problem
Go to the menu and format the card (as long as it's blank) formatting will erase all data from the card
Apr 15, 2009 | Fuji FinePix S9500 Zoom Digital Camera
Fuji FinePix F20 Digital Camera Logo
78 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
