Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Need to replace pump Impeller on A.O. Smith Century Centurion Pool & Spa Duty Switchless Pump
  • 1 more comment
  • Kieran Ruppert Oct 12, 2010
    The pump and motor are two different things. An A O Smith Century is a motor. I would need the brand of pump to help.
  • jim orstrom sr Jul 02, 2013
    proline wet end pump
  • Anonymous Mar 24, 2014
    need cover removal part
    Novelist:
  • 116 Answers
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 12, 2010
Swimming pool pump
check on amazon enter motor or pump number should give you numbers to order from
Jan 19, 2014 | AO Smith Pool Pump Motor Hayward Swimming...
Instructions to replace ao Smith Centurion Switchless Motor
less hassle replace whole pump if motor overheated ruined seals and possible distortion of pump
Apr 09, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
Replace ao smith century centurion b852
take apart normally impeller screw backwards thread but impeller unscrews normally
Oct 20, 2012 | AO Smith A O Smith Motors A O Smith 3/4hp...
How to take apart a pool pump motor
if seals went bearings going shortly if bearings went seals shortly replace whole unit less hassle
Oct 11, 2012 | AO Smith A O Smith Motors Centurion 1/2hp...
How to remove impeller case from century centurion pump
take out screw to impeller backwards thread impeller unscrews normally
Sep 16, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
I am trying to disassemble the impeller from my century centurion pool pump. How do I lock the shaft so that I can unscrew the diffuser? Thank youl.
Under the rear cover or under a small cap on the end opposite the shaft will be the shaft end and it should have a slot or key hole. Use a screwdriver or allen wrench to secure the shaft and then turn off the impeller.
John
Oct 07, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I have an A.O.Smith Century Pool & Spa motor 1081 pool pump duty 1.5 HP. It is making a very loud noise, do you think it needs replacement or should I look for something else?
THIS IS LIKELY CAUSED BY SOMETHING IN IMPELLER TURN OFF POWER SEE IF YOU CAN SEE ANTHING IN IT YOU HAVE TO TURN HANDEL VALVES OFF PUSH DOWN IF YOU HAVE TO OPEN PIPE IN FRONT OF PUMP I
Jun 19, 2009 | Hayward 1.5hp Pool Pump Motor Motor A O...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
3,840 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
