Question about Yukon 24021 Monocular
My yukon scope will not light up. before it was causing a bright green screen on the inside, and now it wont even light up. help lol
HP Desktop 550-a114, will not turn on, though there is a green bright light on the motherboard
take a A+ cert course then tell this fib again.?
An LED can glow at 2vdc, tells you nothing!
only that some weak power is present, nothing more...!
learn that in electronics.
it can fail all theses ways.
good
bad.
weak
intermittent.
the PSU tests are covered here, take a volmeter
not some LED on a stick or parts glowing.
got 50 years of on the job doing this, from DC to daylight, from MIL to you name it.
http://pcdied.com/black-screen.html
Apr 15, 2017 | HP Computers & Internet
2005 yukon will no go in to park
Put foot on brake push shifter all way up. Lol. Seriously of it doesnt go into park your transmission is messed up. Teeth likely broke inside blocking the shift ability. Not common at all. If someone slammed it into park while driving could cause this.
Jul 20, 2014 | 2005 GMC Yukon
What does the green/red recticle do on the bushnell banner 3-9x40 scope ?
Allows you to shoot in low light levels and you choose which colour you are happiest with and brightness level the same
Feb 14, 2014 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
It's like new and hardly used. It starts to come on and you can see the green in the lens, then it goes dark. still shows power is on. I've tried fresh batteries with the same results. Where can I get it...
Hello. you do know that NV devise are to be used during the black hours of the night. Any type of bright lights will burn out the multi-plate coating. It only take a few time and the image intensifier tube is gone. The generation 3 and 3+ image tubes have auto gating that is, if the sensor detects bright lights with shut down. Now, this help but bright light with even the generations of image tube. It will still destroy them.
To get repaired you can send it to ATN in California. Just for them to take a look and see what wrong will $100+ plus shipping both ways and the cost of parts that is, if they have the parts.
What they will try to do, is that they will take your 258 scope in for trade. Then have you up grade from this 6 year old NV scope to a new model. They could also tell you it's not repairable.
Now, I have repair a few of the MK ATN NV scopes, and all the image intensifier tubes are manufactured in Russia, and there is good possibility that the hole scope was manufactured there.
The Russian manufactures will just print the American Vendor name and logo on the scope, monocular, binocular that they manufacture. You send to me and I will take look at and try to find a new image tube for it. drawbridge21.q.com. GB...stewbison
Nov 22, 2010 | ATN Aries MK-258 Weapon Sight
The yukon NVMT 4 was turned ON and then flashed. Cover was on. Now the ON lights, IR Light works but visor is all grey and appear small lighting on bottom corner.
The scope may flicker or flash when used in a bright environment. To fix this you should only use a NVMT in a dark. It will restore itself in a few minutes or hours, depending on how long it has been exposed to light.
It may also flicker for the first several seconds of use in dark, before the device corrects itself.
With a severe exposure to bright light for prolonged time the light enhancing unit may damage beyond repair.
Oct 20, 2009 | Yukon NVMT (4x50) Monocular
I have 2003 yukon that wont start
Please Check your injector. Lack of fuel must have caused a fault in it.
Have an expert see to this for you.
Good luck.
Please rate this.
Apr 10, 2009 | 2003 GMC Yukon Denali
Green as a frog!!
ya take frog out lol jk did u cheak ic chips the cables mixed up ?
Jan 31, 2008 | LG 52SX4D 52" HDTV
Some part of TV has been fused causing no picture on screen , only bright green horizontal lines , not even video channel could be set ,cannot see menu on screen please help by specifying possible...
if the screen is real bright green with thin small white lines in it its probably a shorted picture tube. Or a shorted Green driver Transistor. Good Luck
Apr 12, 2006 | Thomson 14MG135 14" TV
Yukon 24021 Monocular Logo
55 people viewed this question
Top Yukon Optics Experts
John Porter
Wally Jackson
Wally Jackson
Are you a Yukon Optic Expert? Answer questions, earn points and help others
