Question about Maytag MFI2569VE Bottom Freezer French Door Refrigerator
Ice maker is frozen has auto shut off need to remove maker to thaw out to remove ice that is stuck.
    President:
  • 1,891 Answers
Use a hair dryer and a towel under it . this is easer than removng the ice mker . then ck the ice cubes for size as they should not be getting stuck . mm
Posted on Oct 11, 2010
How do I remove the ice maker from a Samsung model RF28HFEDT5R - normally I just lift slightly and remove but it stuck, probably ice restricting removal.
A blow dryer will work fine. but place a large towel so that it will absorb the runoff, but also to shield rest of the frozen food from being exposed to hot air. That may require two towels.
May 17, 2017 | Samsung Refrigerators
I need to thaw the ice that is in my ice maker (Kenmore Elite, 106.56709500), how do I do this? Can I just remove it?
Just get a new ice maker on cheap on ebay since the heating element (for ice removal) on tray will cost more than a new maker!
Aug 25, 2017 | Refrigerators
I have a Jenn Air JRSD209W refrigerator. The ice maker stopped making ice. So far I have replaced the water supply solenoid and the ice maker unit. The unit is cycling mechanically, but no water is...
Check the water line that goes from the water fill valve to the ice maker to see if it's frozen shut.
You can remove the ice maker water line from the water fill valve and see if you can blow air through it. If you can't blow through it then its frozen shut.
Sometimes they freeze shut if the water inlet valve was seeping a little water past it when it was off.
If that is the case you have already replaced it so after thawing the water line out you should be good to go.
Aug 03, 2011 | Jenn-Air Refrigerators
The ice tray is not producing ice and we have the handle up. I think the ice makeer has frozen itself over. Can the ice make be removed or thawed out without unplugging the whole fridge?
the handle needs to be in the down posit. ans if up it shuts the ice maker off. .. you can defrost the ice mker with a turkey baster & hot water . use towel under icemker .. mm
Aug 10, 2010 | Jenn-Air JFC2089HP Bottom Freezer French...
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Frigdaire side by side ice maker is a block of ice
Hi, You can remove the ice maker by removing the two screws on the top that fasten to the wall and most models have a screw on the under side.
Did you have to turn the water source off to stop the water from going into the ice maker? Sometimes a cube will not release and block the ice maker from turning.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Frigidaire FSC23F7D Side by Side...
Ice making feature not working
Most likely the ice fill tube has frozen up and will not allow the water to fill the ice maker. You will need to remove the icemaker (three small screws) and take a hair dryer and thaw out the fill tube. You can use a bent up coat hanger to reach in and remove some of the ice that is formed up in the tube as you thaw out the ice. Also check the Icemaker's actuator arm. This sometimes is hung up by a small piece of ice that hasn't dropped causing the Icemaker to shut off. (This is the first thing to check )
Apr 27, 2009 | Viking Professional VCBB363 Bottom Freezer...
Frozen water in ice tray
You do need to thaw the ice maker out completely. I always remove it but that may be more than you are up to. You can also try a hair dryer on it to thaw it out.
Feb 26, 2018 | Whirlpool GS6NBEXRB Side by Side...
Ice maker doesn't work
When you say you are getting water do you mean you are getting water in the ice maker tray? If so then unfortunately you will need to replace the ice maker. If not getting water to the ice maker then make sure the fill tube to the ice maker isn't frozen shut. If so, thaw it out and see what happens. If it isn't frozen shut then replace the ice maker. New ge ice makers, when installed, will not cycle until the ice maker gets below freezing so you will have to wait once it is installed.
Oct 07, 2007 | GE Profile PSI23NCR Side by Side...
Maytag MFI2569VE Bottom Freezer French Door Refrigerator Logo
136 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
