Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
I turned off the burner and it stays on. - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 22 Answers
Frigidaire has done a voluntary recall on this problem as it is a safety issue. They will send a tech to repair at no charge, depending on the model and serial no. Also applies to Sears Kenmore. Check this site to see if it applies to your range: http://www.laundrypumprecall.com/node42.aspx
Posted on Dec 22, 2010
Burner won't shut off
The problem sounds like the valve is stuck.
Feb 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Burner light stays on
g.e oven model # jbp3wb4ww burner light stays on when burners are off
Dec 10, 2009 | GE Profile JTP18 Electric Single Oven
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
Kenmore electric stove with glass/cermanic top. Element on light indictor light stays on all the time even though no burners have been turned on for 5 hours. None of the burners are hot when you run your...
Tony, this sounds like you may need to have a new burner switch installed, it is called an infinite switch. If it is for the dual burner, make sure you tell the appliance parts store this so they can order you a dual infinite switch.
Nov 08, 2009 | Kenmore Ovens
Hotpoint Glasstop Stove - Burner turns on by itself
I have a GE stove which I purchased in 2004, and it is doing the same. I heard beeping coming from the kitchen in the middle of the night . I went to the kitchen and the oven was on by itself. I have been unplugging it when not using it. Maybe this could be a recall.
Oct 08, 2009 | GE Profile JKP18 Electric Single Oven
BURNER IGNITION WILL NOT TURN OFF. When turning stove top on, all 4 burner ignitions continue to stay on. They will not stop clicking. Only when I unplug the oven will they turn off. It is a Frigidaire...
One of the switches is stuck,causing circuit to 'think' that you're trying to light a burner. Give each control knob a good 'tap' with the back of a screw driver.If that doesn't free it up, we will have to find the stuck
switch
Jul 25, 2009 | Frigidaire FGB24S5A Gas Single Oven
Oven won't turn off
I have a Kenmore model 665.95802 . When I turn the oven dial off , the broiler stays on and on the display you see the code F3 E2
Mar 02, 2009 | Kenmore Ovens
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Spark module clicks and gas will not stay lit, flame comes on but goes out
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
thank u.................
Sep 11, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
80 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
