Question about Ezonics EZCam Webcam
Have Web Cam pluged in. Still nothing camera not functioning. I have an Emachine loaded with Windows Xp. Need step by step instructions on what to do now. Do not have cd to load software.
  • Ezonics Master
  • 2,130 Answers
1st You download Webcam Driver.
Web Cam After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Nov 22, 2013
  • 340 Answers
Follow this link and click on download. Click on run when the popup box comes up, follow all of the prompts and you will have your drivers downloaded. When installing your drivers, make sure that your cam is hooked up. Hope this helps!
Lori
Posted on Oct 11, 2010
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have a dell computer that runs windows xp 2002 on windows 7 and my web cam won't even load the cd for web cam.
Your description is kind of confusing. are you running windows xp or windows 7? Your best bet would be to download the drivers and software for windows 7 from the camera's manufacturer website.
Sep 07, 2010 | Computers & Internet
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
What steps must I take to get my Acer Aspire One web camera to wo
If this unit is running XP Home:
The Aspire One should have come with the webcam driver preloaded so you should simply have to configure Skype or whatever app you wish to use to access the webcam.
Should you need to load drivers however:
There are 2 possible drivers for the Aspire One (in XP), the default driver is for a SUYIN cam (driver download) the other is for a LiteOn cam (driver download) [ try the SUYIN driver first ].
After verifying that the drivers are installed and functional you should be able to pull up Skype (or whichever app you wish to use for conferencing) and configure the webcam for use.
You may want to bookmark this URL in case you ever need to download any XP drivers for your unit...
Feb 20, 2009 | Acer Aspire 5610-4648 Notebook
Web cam
Not all Web Cams turn on automatically, Yours might be one ;-)
Start, Settings, Control Panel. Look for your Webcam, Double click it, wander thru menues/tabs to find ON or Enable button. Close. Use
Jan 14, 2009 | Microsoft Windows XP Home Edition
My Windows NX-3000 Web cam wont let my PC load
Normal 0 Did you connect the camera before installing the software program? If you did, disconnect the camera from the USB Port and reinstall the software program. When the program asks you to reconnect the printer, then plug the cable back into the USB port and it should function properly.
Hope this is of some help. Bud
Dec 26, 2008 | Microsoft LifeCam NX-3000 Personal Web...
My web cam
You can download the drivers from GENUIS's site:
For Windows XP
For Windows Vista
Hope that helps!
Sep 06, 2008 | Genius VideoCAM Eye Web Camera
Pc web cemera driver software
i loss my pc web camera driver cd and in want to installed pc web camera in windows xp so can i get any help from you. i just need a drivers & software
Jun 15, 2008 | PC Concepts 300K Webcam
Web cam drivers for model CS330
i want to download drivers for usb web cam oprating system is xp
May 15, 2008 | Intel Deluxe PC Camera CS330 Webcam
Head Gear WC755IPT Web Cam
I have a suggestion.. pls install SP2 of windows xp and try again..ok
Jan 04, 2008 | Microsoft Windows XP Home Edition
Ezonics EZCam Webcam Logo
66 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
vojvodabudva
Rommel Balcita
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
