Question about Refrigerators
Freezer not cooling fully - Refrigerators
  • 2 more comments
  • njacobjohnso Oct 11, 2010
    Sorry for the the lack of details, had some technical difficulties with payment going through and didn't think it posted this sparse one.
    Anyway, model # is RB195BSSW, is a samsung refrigerator with bottom mount freezer. It is probably about 4, maybe 5 years old I would say.
    Refrigerator is working fine, freezer gets down to about 32 degrees, sometimes colder, but temperature fluctuates quite a bit and doesn't get as cold as it is set to. Doesn't get cold enough to really freeze meats and such. I tried running a diagnostic test by holding down Power Cool and Power Freeze buttons for several seconds. When I did this the bottom of the leftmost "8" in the LED display lit up. Haven't been able to track down what this corresponds to.
  • njacobjohnso Oct 13, 2010
    I left a comment for the prior user, not sure if you could see it or not:
    Anyway, model # is RB195BSSW, is a samsung refrigerator with bottom mount freezer. It is probably about 4, maybe 5 years old I would say. Refrigerator is working fine, freezer gets down to about 32 degrees, sometimes colder, but temperature fluctuates quite a bit and doesn't get as cold as it is set to. Doesn't get cold enough to really freeze meats and such. I tried running a diagnostic test by holding down Power Cool and Power Freeze buttons for several seconds. When I did this the bottom of the leftmost "8" in the LED display lit up. Haven't been able to track down what this corresponds to.
    Can you provide idea on the diagnostic code?
    Sorry for the the lack of details, had some technical difficulties before. Anyway, model # is RB195BSSW, is a samsung refrigerator with bottom mount freezer. It is probably about 4, maybe 5 years old I would say. Refrigerator is working fine, freezer gets down to about 32 degrees, sometimes colder, but temperature fluctuates quite a bit according to the LCD display and doesn't get as cold as it is set to. Doesn't get cold enough to really freeze meats and such. I tried running a diagnostic test by holding down Power Cool and Power Freeze buttons for several seconds. When I did this the bottom of the leftmost "8" in the LED display lit up. Haven't been able to track down what this corresponds to. Thanks.
  • njacobjohnso Oct 15, 2010
    What i really need to know is what that diagnostic code corresponds to, thanks.
    Master:
  • 397 Answers
Have you defrosted your freezer? Basically this means removing any ice stuck in the fins at the back of your freezer (I find a combination of a good hair dryer and warm water work well- salt water would work better, but cause potential issues with rust and other corrosion). Have you cleaned out the coils on the refrigerator itself? Dust coating the coils ruins the efficiency of the heat transfer process... basically putting wool socks on a hot foot. Both of those would help your freezer go back to working normally. If not, there are other possibilities- like checking the settings on the freezer's thermostat, and if possible- the coolant. However, further than that, I would recommend getting an experienced repair person to examine/repair. If the refrigerator is still in warranty, I would contact the warranty holder for service- or how to get service.
Posted on Oct 13, 2010
  • Susan Fender
    Susan Fender Oct 13, 2010
    It sounds then like the thermostat controls for the refrigerator are going out- this would be in the computerized portion of the unit- unfortunately, unlike Central Air- I have not seen replacement controls for your refrigerator. Digging info on the specific model agrees with this assessment. Basically, other than trying the old unplug and replug in the refrigerator, the next step for you to resolve the issue is get the refrigerator serviced. I am not certain if your refrigerator is in warranty, however there is likely an issue in the panel for your refrigerator.
  • 1,040 Answers
Before you go and try replace any parts, you will want to clean the dust off of the fridge parts. When a fridge doesn't cool properly it can often be because of dust.
You need to clean the front. If you are looking at your fridge, down along the floor you will see a plastic cover with vent holes. You need to pop this off and vacuum the dust off of the grate. You will need to vacuum the back of the fridge as well. And if you have a shop vac, after using the vacuum part of the vacuum, then put the hose on the blow side to clean the areas that you couldn't reach. Make sure to unplug the fridge before cleaning.
Good Luck!
Jim
Posted on Oct 15, 2010
  • 3,530 Answers
There a multiple reasons why the freezer is not cold enough. Please click on this link to see how to troubleshoot.
Check the temperature setting
Assure that there is enough room for air flow in the refrigerator or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condenser coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Posted on Oct 12, 2010
  • 10,515 Answers
Kindly mention few details :-
1. Make and model of the refrigerator?
2. How old is the unit?
Thanks!!
Posted on Oct 11, 2010
Freezer not freezing
please fully describe the circumstances; what is the fridge doing? is the freezer cooling at all? is the freezer overstuffed? how old is the unit? what make is the unit?, etc.
Oct 17, 2016 | Refrigerators
LG 262SQA Model fridge cannot cool
That does not look like an LG model number, but regardless, it sounds like the defrost system is not working, allowing frost to build up and block air flow over the cooling coils in the freezer (where all the cooling for the entire refrigerator takes place). Take back panel off inside freezer, melt frost / ice with a hair blower. Test for continuity through defrost heater and replace if "open". If it was OK, problem could be deftost control, or as simple as a door not fully closed at some time, allowing excessive frost build up.
Nov 18, 2011 | LG Refrigerators
The bottom freezer is working fine, but the top part is not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Whirlpool GX5FHDXV (248 cu ft) Bottom...
My bottom freezer gets cold but the top part (fridge) does not. Why? I have an older first addition style
Its defrost problem.When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
May 19, 2011 | Amana ABB1927DE Bottom Freezer...
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
