Question about Cell Phones
Motorola V9 powers on when pluged in to charger but gives an "UNABLE TO CHARGE" error. Tried differant battery with same results. As if battery is not making contact.
  • 358 Answers
Hi,replace the charger,problem will be solved.
Take care.
Posted on Oct 11, 2010
  • nber Oct 11, 2010
    Tried different chargers, tried different Batteries with no results. It is as if the connection from the battery is bad. Phone works normaly when pluged in to charger and stops as soon as it is unpluged. Tried cleaning connector but no better.
  • jersey mark
    jersey mark Oct 12, 2010
    Hi, the problem is from the phone board. The charging port where you insert the charger on the phone is not contacting properly or is weak and about to get damaged, you can unscrew the phone to check it out.
    If the connection is intact,that means you will have to replace the charging port(place on the phone where you insert the charger).
    Take care.
Phone says unable to charge, after a new battery install. when you plug the charger in phone comes on
Check the contacts between phone and battery, if necessary align or clean. Are you using original Motorola charger? This solved my problem; I was trying to charge it with one of those "universal" chargers.
Hope this helps!
May 08, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
New battery will not work
you most likely have "overcharged" your battery, or your battery isnt working... Buy a new battery
Jun 30, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Rarz V9 won't charge...pllzzz hellp mee!!
I have the exact same problem as yours for the last couple days, and FINALLY IT IS CHARGED last night using the USB data connection cable. I don't know the exact problem with other chargers, including car and regular outlet chargers, but it works with the USB connection from a computer. GOOD LUCK!!!
Jun 09, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
"unable to charge"
I had an old Motorola V3, which used to show me that error. It could result if the charger is not firmly connected to the phone. To diagnose this, try borrowing someone's moto charger. It's also possible that battery contacts could have dust. Try dusting them off so that they're nice and shinny as usual. Finally, try removing the battery for a few minutes, reinsert and charge, leave the phone off when you charge. The phone usually starts working after the regimen. If the problem persists, you'd know which method worked and what failed, so you can press for a warranty. Cheers
Jun 02, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Battery
If you tried to make a charger you could have damaged the Pinout or even the charging port on the phone however 99% of the time this common error with razrs is fixed by trying a different battery and or a different charger.
Jan 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
