Question about TORK Variable Cycling Timer 8601
I have a 110 Pool Pump and I am trying to wire it into a Tork1103NC timer. From the pool pump I have a black, white and green wire that I need to wire into the timer. Can you tell me what position those wires go in?
Here is Tork 1103 wired for single load.
1) The green pump wire and bare copper wire go to green ground screw
2) Pump black wire goes to pole 2, the NO (normally open) pole
3) Pump white wire goes to unmarked screw
4) Black from circuit breaker goes to pole L
The T1103 comes with a removable brass bar that connects pole L and pole 1
If that removable brass bar is not there, then add a jumper between pole L and pole 1 as shown in diagram above
5) White neutral from breaker box goes to unmarked pole (all whites connect to unmarked pole)
In your case, pole X is not used. Pole X is NC or normally closed > which means the power is ON continuously until timer turns on, and when timer turns ON, the NC pole turns OFF
Posted on Oct 11, 2010
Wiring a Stark 220V 1.5 HP pool pump
you cant run a 220 pump on 110.. thats what youhave..need a 220 circuit to do this..the black is hot.. the white is neutral and the ground goes to the casing of the appliance but this wont run .. you need a 4 wire line..black/red/white/and earth ground(bare wire)..220
Dec 22, 2013 | Pool & Spa
Wire t104r
look at inside cover for wiring line is voltage coming in and load goes to pump
Aug 06, 2013 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Wiring for timer
T101P3 is ordinary 120Volt T101 mechanism inside a beige plastic box.
Rated 40 amp.
Three terminals A 1 2
Very small white wires that power the WG1570 clock motor are connected to terminals A and 1.
White neutral wire from breaker box connects to terminal A
Black Hot wire from breaker connects to terminal 1.
This will power the clock motor, which will switch the timer on-off.
Green ground wire and bare copper wires connect to green ground screw.
115volt motor should have 2 wires.
Connect white wire to terminal A
Connect black wire to terminal B
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Aug 21, 2012 | Intermatic T101P3 Pool Timer IndoorOutdoor...
Im hooking my pool pump up to a 220 and I dont know what wires go where. On the motor there is a A and B and a L1 and L2. What do I put my brown wire on and what does the white one go on. Can u help me...
There should be a diagram on the side of the motor showing you where to put the brown and white for 110/220 volt operation. Most new motors of this size are shipped strapped for 220v. The two hot wires will go to L1 and L2 and it doesn't matter which wire goes to which lug. For 220v you will usually have 2 black or 2 red wires and a green ground wire. If it is 110v supply, you will usually have a white and a black wire, and a green for ground. Hope this helps. Since you said you are hooking to 220v the brown and white should be on the correct lugs if this is a new motor.
Jul 19, 2011 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I am trying to wire a new Emerson 230v pool pump to a timer. The pump has 2 red wires and 1 green wire coming from it. The timer has 3 wire terminals. The receptacle has 1 black wire, 1 white wire and 1...
You really need a 2-pole timer -- 2 wires in and 2 out. In that case the Black/White from the receptacle goes to the 2 "in" terminals and the 2 red wires from the pump go to the 2 "out" terminals. The WHITE wire from the receptacle goes nowhere - tape it off. The Bare wire from the receptacle goes to the GREEN (ground) wire on the pump.
A single-pole timer can be used, but in that case, you ALWAYS have 110 v on one side of the pump. Not safe, and not code compliant.
May 27, 2017 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
Aug 22, 2010 | Intex '10 Saltwater System Pool...
1031 Pool Pump 3 wires Purple, Green & black . where do the Green and Purple go?
I am assuming that you have a 220v pump motor there...the black and purple are the "hot" wires hooking to the 110 legs and the green is the "ground" hook it to the metal frame.
heatman101
Apr 20, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Which wires go to L1 and L2 on a pool motor HP1.5
I think yours is a 220 V AC pump ... L1 would be the "black" wire and L2 would be the "red" wire. Please check your motor documentation to confirm this.
Alternatively, this pump can run on 110 V ... again, please check your documentation.
I would expect you have 12/ 2 with ground wire coming from your distribution panel to this pump. The wires are now Black and White and Bare or green. You can use this wire for 110 or 220 depending on whether you use a single pole or double pole breaker. The #12 wire should be good for 20 amps at 110. If you do the 220 thing, the white wire becomes "red" and connects to the other pole of a double pole breaker (black connecting to the first pole).
The load imposed by the pump on the circuit is well with in the capability of the #12 wire as long as this is a dedicated circuit.
I hope I have not confused. If I missed the mark on this, please post a comment to your question and I will tru again.
thanks
a
Oct 19, 2009 | Hayward 1.5 Hp Northstar High Performance...
Wiring My Pool Pump
that pump is probably prewired for 220volts. you will have to check the diagram for how to configure it to 110v. most motor can be converted to 110v. If you are not comfortable with reconfiguring, contact a service tech.
Sep 13, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
TORK  Variable Cycling Timer 8601 Logo
615 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
pawnpower
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
