Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Just replaced the blade. now when i pull the cord, gasoline spurts out of muffler
  • 394 Answers
Take out the spark plug, then pull the rope a half dozen times or so. Tap lightly on the bowl of the carburetor. Blow on the bottom of the spark plug to dry.
Put the plug back in. Give it a try.
When you had the mower up to remove the blade the float in the carburetor bowl may have stuck open flooding the engine with gas.
If this works you may want to change the oil as some gas probably got in your oil.
Good Luck,
Wayne
Posted on Oct 11, 2010
Procedure how to start new mower
Make sure you have the proper amount of oil in the engine
Make sure your new blade is on tightly. Pull spark plug wire off.Check and see if you can turn the blade by hand one complete turn to make sure nothing is holding blade back. Sometimes the factory puts a block under neath for shipping. Replace spark plug wire.
Fill with the proper gasoline
Should be ready to fire up. Push primer bulb three or four times and pull cord and it should run. Sometimes you have to push primer bulb more than they recommend in the book.
Sep 29, 2014 | Craftsman Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Sears gas leaf blowers require you add 2 stroke motor oil to each refill of gasoline. I failed to do so and now the blower will not restart. In fact, the pull cord to start the gas blower is seized. How...
You can remove the spark plug, and put some penetrating oil in the cylinder. Some people use deisel fuel or marvel mystery oil. Then put the plug in hand tight and set so the plug points straight up. Since this is a two cycle instead of a four cycle you may have the fluids drain out. If they do drain out I do not think there is anything to do to save it. If the fluids stay, let sit vertical for a couple days and then remove the plug and try to pull the starter cord. Due to the design factors of two verses four cycle, the fluids do not drain out with fours like then can with twos. I hope this is helpful.
If you do get it freed up, you then will need to remove the muffler and inspect the side of the piston. The muffler side tends to have the most damage. If it is bad you will probably just have to replace it. If not damaged much, then you got lucky and should go get a lottery ticket.
I hope this is helpful for you.
Aug 31, 2011 | Sears Garden
The blade will not turn on my Ranch King 6.0. I cannot budge the pull cord and can barely turn the blade manually. What can I do?
check to see if it is if the cylinder is full of gasoline. remove spark plug and turn motor over.
caution, disconnect and ground spark plug wires, do not stand in front of spark plug hole, you may get sprayed with gasoline. spin motor with starter or pull rope.
if this doesn.t free up the blade look under it for "stuff around the drive shaft. clear it out.
other solutions are expensive and involve bent cranks.
May 24, 2011 | Garden
Can't pull the starter cord, it's very hard to do. Removed spark plug and then the pull cord worked fine. Put the spark plug bvack in and once again the starter pull cord was hard to pull. Seems...
Hi and welcome to FixYa, I am Kelly
Remove the muffler and clean out the exhaust port and screen. You will have to disassemble the muffler and clean off or replace the screen item 8 of this link:
http://www.partstree.com/parts/?lc=echo&mn=CS-330T++S%2FN%3A+C08611001001+-+C08611999999&dn=7946
Before taking the muffler apart... unhook the spark plug and just pull it though with the muffler removed. If it pulls normally you know you have found the problem.
If it still pulls hard...check the exhaust port of the cylinder head for 2 tiny holes (not screw holes) Some have them some don't depending upon the year of the saw. If you do find 2 small holes that appear clogged with carbon... do your best to clean them out.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Echo CS400 18" Chain Saw
Pull cord or motor frozen didnt put no oil just gasoline
Unfortunately, your Echo blower gets all of its lubrication from the oil mix in the gas.
To inspect the damage, remove the muffler and look inside the cylinder with a flashlight. If you can see scrathes or scoring along the sides of the piston or cylinder walls, then there are only 2 options. Repair or replace.
The repair would involve replacing the piston and cylinder (parts are $150) If you can do the labor, that would save probably $100.
To replace, I found several on ebay and other online sites for less than $300 plus shipping.
Good luck.
Nov 03, 2010 | Echo Gas Blower 162 MPH 450 CFM Blower...
Ryobi 2 cycle 31 cc E-Z Pull Gas Trimmer (18 inch cut; straight handle) will not start. Have checked fuel lines and replaced Spark Plug with correct size. Gas and oil mixture is correct with fresh, clean...
The "grinding-type" noise is disturbing. This could indicate that a piston ring has broken loose and is scoring the cylinder wall and would likely be a significant or terminal problem. I will assume this is NOT your situation. Well done on your description. Follow this:
1. Best to determine if you have spark to the spark plug by removing the spark plug, plug it into the plug line and ground it the best you can to a metal surface on the engine. Pull sharply in a dim light and insure you have a spark. [If yes: Go on / if no: replace the spark plug and retry. If yes, replace spark plug and retry your efforts. If no, your machine will need a professional, on-site review).
2. Carburetor repair kits are inexpensive and are DIY for many. Diaphragms over time become in-flexible with modern fuels that were not well drained from the machine out of season and may not be pulling the fuel into the carburetor and into the machine. This may be your case.
3. Exhaust or mufflers can become clogged with carbon buildups at the screen or within the muffler itself when running lower quality 2-stroke oils or too low of a ratio to fuel. You can often pick-clear the muffler or replace it.
These are the most common issues encountered...other than, switching the machine to the ON position - good luck!
2. I
Sep 25, 2010 | Ryobi Garden
Chain saw pull start won't work
Remove the starter assembly from the engine and try to turn the flywheel by hand--it should move freely except when the piston is beginning compression. If the flywheel won't turn, then remove the muffler and check the piston skirt and cylinder for severe scoring. If it is, then suspect that the engine was run on straight gasoline. This damage will be quite expensive to repair as the cylinder, piston, and ring(s) will require replacement plus labor if you farm the work out. If the above check revealed a freely turning flywheel, then check the starter mechanism looking for a bound starter cord or other obstruction. If the spool can't be turned CCW, then suspect that the spring is over-wound and can't be turned further--remove the starter cord after wedging the spool so that it won't unwind completely, the loosen the wedge and turn the spool CW about 5 or 6 turns, then re-wedge the spool again. Reinstall the cord (replace it if badly worn) by melting the cord end, then tying an overhand knot to retain it. Wind the cord CCW 5 or 6 turns, then thread the cord though the cord port, slide the handle on, melt the cord end, and tie another overhand knot to retain the handle. Hope some of this helps!
Jul 12, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Pulling string on weed eater does not want to turn
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
Jul 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
