Question about Canon PIXMA MP190 All-In-One InkJet Printer
The printer keeps flashing e then 2 and when i try to print it says it is error 5100
  • Canon Master
  • 16,124 Answers
I have an MP130. I find that when I have a 5100 error you just need to change the cartridges even though the software may say there is ink left in the cartridge. I think there is a chip on the cartridge itself when sends a message that the printer doesn't understand.
First off though you can disconnect the printer from the outlet, count to 10 and then switch it back on. Also, don't be tempted top refill cartridges or use anything but genuine replacements unless you want problems! Been there, done that :>)
Posted on Oct 11, 2010
Printer error code 5100
I got error 5100 after a paper jam. There was a small piece of torn paper stuck in the gears, and I had to mess around and move the print cartridges back and forth to get seated back on the ink pads to the right of the printer (if you're looking at it from the front).
Reset the printer by powering it off for 10 seconds and try to repeat a test print.
I was able to get mine to work after a few tries. Good luck.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
let me know if this is helpful to you
Dec 09, 2009 | Canon Office Equipment & Supplies
Service error 5100?
This error means that there is something obstructing the printing process. Check inside your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt or in my case popcorn. There was even some paper caught underneath the rollers that I had to jiggle around to even see. Check VERY thoroughly.
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
Also, try this reset procedure:
1. Turn off printer
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Office Equipment & Supplies
Error 22
1. Turn off printer
Jan 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Print Sometimes, and Sometimes Error 5100
1. Turn off printer
here is the link for other printers: http://www.cyber-ink.com/member-canon.html
Jan 08, 2009 | Canon PIXMA MP470 All-in-One Printer
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
Service error 5100
Hello it only a try but could be
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Jul 28, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Error 5100
where is the best place to get this repaired>
Nov 06, 2007 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
129 people viewed this question
old marine
old marine
