Question about Maytag Dryers
I need to know how to wire a 4 lead pigtail on a maytag performa dryer
    Sergeant:
    Champion:
  • 351 Answers
Hi from left black 1 white middle red 3 green goes to ground or frame jim
Posted on Oct 12, 2010
Need to know cu ft capacity of maytag performa dryer model pyet344ayw
Go to support on the Maytag website. Enter your model number, click on downloads, and select an owners manual.
murf427
Aug 04, 2012 | Maytag Dryers
How do we change a 4 wire pigtail to a 3 wire? The 3 wire doesn't have color coded wires?
Hi.
Here is a tip that shows you how to hookup your 3 prong dryer plug...if you don't have colors the black wires are interchangable...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to connect a four wire pigtail
The white wire goes to the middle terminal post on the dryer.
The red and black wires go to the outside terminal posts.Doesn't matter which.
The green ground wire needs to be attached to the outside metal case...anywhere. The easiest way is to put the eyelet on the screw that attaches the terminal cover plate when you put it back on. Sandwich it between the screw head, the plate and the case.
Hope that helps. Let me know if you need more info
Best, G
Aug 02, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 14, 2010 | Maytag Performa PAV2200
I am in the process of trying to hook up a 3 prong electrical cord to a 4 prong but dont know which colored cords go where? any advice?
Get an qualified person to do it. If you do not have any idea how to do it, you are better off having someone else do it. If you have a 3 prong receptacle, you need a 3 prong pigtail. And if you have a 4 prong receptacle, the dryer needs a 4 prong pigtail. The green is ground, white is neutral, red and black are both hot (L1 and L2). If you put a 4 prong pigtail on, remove the ground strap between the center post and the case. The green ground goes on the case, white neutral in the center, black or red to the left, what's left on the right. You can interchange the red and black but NOT the white or green. If you use a 3 prong pigtail, the center is the neutral (same as white on the 4 prong) and you will need the ground strap between the neutral (center) and the case. The wires do NOT cross over on a 3 prong pigtail.
Dec 31, 2009 | Maytag Dryers
Need to connect 4 wire pigtail to replace 3 wire
The following link explains how to convert a 3-wire to a 4-wire power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the Neutral (White) and the Ground (Green or Bare Copper) wires are terminated at the terminal block. In a 4 -wire configuration these wires are independent of each other. In other words, neutral does NOT get grounded.
If you have any questions, please let me know. I hope this helps you.
Oct 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
