Question about Frigidaire ATF6000ES Front Load Washer
The washer is not dispensing fabric softener. The softener does not empty from the container
Jimster
  • 240 Answers
SOURCE: Bleach and Fabric Softener Dispensers don't work
Need a litle more inflormation from you if you could. What is the make and model number of the unit? Does water flow through the dispensers for rinsing action? If it is a front loader or higher dollar machine, the dispensers are sometimes controlled by the timer or control boards. They control water valves that control the rinsing water entering the chambers. This raises the level, and causes a siphon or flushing action at certian points of the wash cycles. There could be a nuber of issues, a bad timer or control board, bad water solinoid(s), wiring issues, or clogged hoses or ports. If this is a new washer, do you still have a service policy or warranty left with it? Let me know what kind the unit is and a model number and will try to help you out a little more. Thanks Jim
Posted on Nov 18, 2007
  • 1314 Answers
SOURCE: Fabric softener will not dispense
water remaining in the dispenser is normal doesn't mean its not dispensing consult your owners manuel
Posted on Jan 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
SOURCE: Maytag Neptune FAV6800AW - Fabric Softener dispenser doesn't empty
I had a similar problem with the fab. softener chamber. Clean
out the buildup and it will drain. To do this, remove the cap and wipe out the softener. Also, be sure to wipe inside the drum, just below the dispenser.
As for a water flow to the dispenser- You will need to remove the plastic portion of the lid. Start with the detergent dispenser, then gently remove the bottom corners of the lid. Then are held by two plastic clasps. Then gently remove the "L" shaped plastic holders. Use a pipe cleaner to clean out the tube where the water flows directly out of the unit, before entering the lid. I did this last night, and it works beautifully!
Posted on Jul 19, 2008
  • 220 Answers
My wife reported the same problem and I took the top off the washer (2 screws at rear of washer and top slides forward) . Under the top on the left front side behind is the dispenser. On the top is a click adjuster similar to a clock hand pointer and in the center is a tick mark and off to the left side is (-) marks for reduced dispensing and to the right (+) marks for increasing dispensing. I moved the pointer all the way to the plus side and after a few loads the dispenser works fine. I assume over time the different fluids (fabric softener, detergent, etc) tend to gum up the valve mechanism. If this doesn't work I would try pouring some very hot water in it to try and loosen things up. After you try all the free thing, I guess the last option is a new dispenser.
Posted on Dec 28, 2008
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
Fabric softener dispenser will not empty
Hello Mike Oswald - Fabric Softener is a very thick liquid that can clog up the siphoning mechanism. Try the following steps below.
  1. Remove the Dispenser
  2. Remove the Inset in the dispenser
  3. Clean out the dispenser and dispenser cover
The Fabric dispenser needs to have the hot and cold water at equal pressure for the fabric softener dispenser to operate properly.
1. Turn on the hot water fill then cold water fill at the washer. If the Wash Sense or temperature sensing is on it needs to be off.
  • If they seem to fill at the same pressure then you will need to contact a professioanl to move forward accurately.
  • If they seem not to fill at the same then you need to correct the pressure.
Mar 03, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool duet washer fabric softener dispenser does not empty
Hi there
I wonder why, mine does though I never use a fabric softener, the water just runs through. It must be clogged somewhere, the only solution I have is the old one. The needle and the thread,try puting a needle through then pull the thread back and forth.
I hope it works
kolbrun
Mar 24, 2012 | Whirlpool GHW9150 Duet Washer
Bleach and fabric softener dispenser will not empty out. Have rinsed the container but problem persists
hello, so you cleaned out the dispenser and cleared the holes under the dispenser cap. low water pressure or blocked fill valve screens can cause this problem also. remove the hoses from the back and make sure the screens are not blocked. hope this helps..ken
Jun 07, 2011 | Maytag Neptune MAH7500WH Front Load Washer
The fabric softener dispenser will not empty on my Frigidaire FTF530FS.
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 24, 2011 | Frigidaire FTF530FS Front Load Washer
Fabric softener container doesn't empty
Softener dispensers are a "Hot or Cold" sort of proposition. Meaning they work or they don't. Each make is different as to where the water comes in at. Your best bet would be to contact a technician to come out and do a THOROUGH test of the machine.
Dec 14, 2009 | Washing Machines
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
140 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
