Question about Delta Home
I installed a delta R11600 3-port six function diverter for a shower to control between the hand held spray and fixed shower head. Per the instructions provided I selected the ( 3 function blue bottom ) stem extender. I assumed the 3 positions would be "off", "hand spray", and "fixed head". But that's not what's going on. One of the positions is the fixed head. The other two positions split the water pressure between the hand spray and the fixed head. Can you tell me what I need to do to resolve this? Joe
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
KMusselmann
  • 247 Answers
SOURCE: vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Posted on Mar 26, 2009
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
  • 129 Answers
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
My grohe 5 spray plus hand held shower is locked in the hand held position and I can't get the top shower head to turn on. The control used to switch easily from top spray to hand held but is now locked...
The control may be clogged with mineral deposits and consequenly unable to function. You can try disassembling the shower to remove the deposits but it may be necessary to replace the complete unit.
Feb 13, 2014 | Grohe 28.444.AV0 Movario 5 Spray Hand...
Hi, We have a old 5-port diverter valve (Grohe 29 605) in our shower in which the outlets are connected thus: Hand held shower port connected to hand held shower Fixed head shower port connected to body...
yep replace the unit the plumbing will be ok for a new unit, with a setup lie that whoever installed it hopefully was smart to put shut off valves behind the wall or you will have to turn off h20o supply and replace and solder caps on the rest easier to change out to new
Mar 04, 2017 | Plumbing
I just installed the valve new. I have a shoewe head and a hand held that feed from the unit. It was intended to 1) serve the shower heas alone, 2) serve the hand held unit alone, 3) put water to both...
Assuming that your two heads are fed from the typical curved wall mounted shower pipe, what you need is a diverter valve. Removed both heads till it's down to just that curved pipe. Get a diverter valve from a plumbing supply store. Tell the sales folks that you want to install a diverter valve so that in one position, the hand held receives water and in the other, it cuts the hand held and puts it to the reg. shower head instead. They should give you a "T" sort of fitting. The female threads of this screws into that curved shower pipe. Then you will find two male thread ends. These connect to both your shower heads. Finally there will be a push/pull knob that is operated to control which head gets the water.
Nimsgame
Feb 13, 2011 | Home
Where is the filter screen in my delta hand held shower head
I is at the end of the hose where it attaches to the hand held head.
Jan 31, 2011 | Delta RP48770PB Traditional Three Function...
Can this diverter run both the shower head and a hand held shower.
This unit will allow the function of the shower head or the hand held shower individually. You can make both operate at the same time but the performance will be dismall at best.
Oct 23, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
No hot water
you have to take the handle off
there should be an insert that you can adjust by pulling out and turning
May 28, 2009 | Delta & Single Handle Shower Faucet
Water trickles out of hand help head
the problem is probably not in the actual head but in the valve body where the diverter is attached. It is easy to google something like "how to change the washers on a faucet" and you will find step-by-step instructions on how to do so.
http://www.dummies.com/how-to/content/how-to-replace-a-washer-in-leaky-faucet.html
May 16, 2009 | Delta Faucet Delta 75582 In2ition 2-in-1...
Home Logo
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
