Question about Symbol LS1908T Wired Handheld Barcode Scanner
I have a Symbol 1908T-1200 which works fine, but I need it to send a line return code after the data. How do I accomplish this.
    Scholar:
  • 117 Answers
Hallo Jason,
yes, this can be done automatically, just by scanning three programming barcodes. Please follow the steps in the attached document.
https://docs.symbol.com/attachments/ADC-01244.doc
Posted on Nov 02, 2010
Why do i have to press enter after i scan
You need to configure your scan wedge or terminal emulator software (which usually includes wedge functionality) that processes scanned data to append a carriage return onto the end of what it is sending. Most software includes this as a configuration option, though sometimes you have to manually append a Carriage Return (ASCII code 13, Hex 0x0d, terminal emulation \r)
Jan 21, 2014 | Symbol MC70
How do i program the LS2208 not to send the EAN-13 check digit and send ENTER key / carriage return
LS2208 needs a ADF Rule added to it to send the "Enter" on the end of all code. Scan123 is also an easy solution. Download it if you don't have it. Basically in Scan123 select the type of scanner you are working with, then select the ADF Rules tab. Make a new rule that says ANY Code, Any Length, and then under actions I put Line 1 "Send all that remains" Line 2 "Send Numeric Key <Enter>. Save the rule. Then select the Symbologies Tab, Select UPC/EAN Tab and select what options you want. Then select the Print Icon, Tick Symbologies , ADF Rules & Programming BarCodes boxes. Print them out and then scan them into your scanner. Job done
Feb 15, 2011 | Symbol LS2208 Handheld
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
I have Symbol scanner(1908T-I300) USB Type. It can read bar code but can't move next cell or line when testing Excell or Note Pad.
In the barcode is usually no order, which would say to the computer to change to new line or cell.
You would need to add an suffix to the barcode, check the manual for the procedure or use the following tutorial http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12295&sliceId=SAL_Public&dialogID=189588227&stateId=1%200%20189576907
Aug 16, 2010 | Symbol LS1908T Wired Handheld Barcode...
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
Problems with M2004 Barcode Scanner
If your M2004 is connected with an RS-232 cable such as the CBA-R01-S07ZAR or the 25-32465-20R the scanner defaults to sending data at 9600 baud, 8 data bits, 1 stop bit, no parity, software or hardware handshaking. Is it possible the software needs to see a carriage return after the data? If so, Scan Options, Data Suffix, Enter from Adobe page 135 and 136 of 310 of the M2000 Series Product Reference Guide will make the scanner send a carriage return line feed (7013). If your program needs just a CR then scan the Scan Suffix barcode from page 134 of 310 followed by a 1, a 0, a 1 and a 3 from page 175 of 310.
If this does not help or if you are connected any other way and the CRLF does not help it may be a good idea to contact the Motorola support center for assistance. Their phone number is 800-653-5350.
Oct 22, 2009 | Cyclone Symbol M2004 Omni-Directional...
Need my p470 symbol scanner to auto enter
It depends on whether you are using a keyboard wedge or a serial connection. Use 123Scan or MCL to make a change to the ADF file that tells the scanner what to do. Then you will have to upload the file to the scanner.
Appending an "Enter" to a scanned bar code
(Keyboard Wedge connection)
Scanned bar code data 04843100Criteria 1 Code type = Any
Criteria 2 Code Length = Any Length
Action 1 Send all that remains Action 2 Send Value Keycode = 7013 <Enter> (String field must be empty)
Output after ADF rule 04843100<Enter>
Note: To have an ADF rule applied to all scanned bar codes, leave the criteria unspecified (Code Type = Any and Code Length = Any Length).
Appending a "Carriage Return Line Feed" to a scanned bar code
(serial connection)
Action 2 Send Value String = \0D\0A
Note: Keycode value is ignored when string field is populated.
Output after ADF rule 04843100<Carriage Return Line Feed>
Dec 25, 2008 | Computers & Internet
Symbol LS1908T Wired Handheld Barcode Scanner Logo
375 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
